Old 03-07-2014, 12:29 PM   #1
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Need Stabilizers?
We learned from some older Airstreamers who rarely, if at all, used their stabilizers. Since that time, in 2007, we have used ours only when parked and unable to reorient against buffeting from a broadside wind. If we can turn our back to the wind, we're steady again. If we can't then at least it feels like we won't get turned over (even tho we know that won't happen).
Bottom line on our 25' International, the stabilizers seem to add no benefit to us except rarely. We don't need them. We don't mind the mild rocking, saves eight more operations to unhitching/hitching, and our entry door always operates better without stabilizers.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 03-07-2014, 12:57 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
You must be svelte folks. My partner and I are each well north of 200 lb, and he's what I like to call an "active sleeper" so every time he flips over in the bed without the stabilizers down, the whole trailer quivers a bit. The stabilizers don't eliminate that, but they reduce it tremendously to the point that it never wakes me and doesn't make the locker doors make little ticking sounds as they wiggle like they do without the stabilizers down.
I put the BAL stabilizers on our 24' Argosy before putting new axles on... with the old axles, I was almost disappointed that I'd spent the money and time on them. When camping by myself I didn't notice a huge different with them down or up most of the time. With new axles, the difference is pronounced.
David
Old 03-07-2014, 01:13 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If the enrty door is difficult to close the stablizers are supporting the coach such that the coach is flexing and the door opening has changed positions. Making the door difficult to operate.
The stablizers were not designed to remove the load from the running gear and front jack. Only to control or suppress the movement of the coach when parked. It is not necessary to use the stablizers when parked. It is only for your comfort. The other usage would be in long term storage as an added prevention for trailer tip over.
If you do not see a benefit when parked by all means don't use them and save your self some steps.
>>>>>>>>>>>>Action
Old 03-07-2014, 01:47 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Sometime we use our stabilizers, sometimes we don't. In old Lucy (2005 25FB), we didn't use the stabilizers very often until she got older. In the last couple of years, we used them more often because of the squeaks she developed which were very noticeable as we moved about the trailer. Using the stabilizers, stopped the squeaking. On New Lucy (2012 23FB) we are not using them.
Brian
SuEllyn & Brian McCabe
Old 03-07-2014, 02:02 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We only use the stabilizers if unhitching from the truck, or if strong winds are forecast. Overnight stops we leave them up to make things easier and minimize risk or driving off with them down.
Doug and Cheryl
Old 03-07-2014, 02:03 PM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I use them because the trailer wiggles with every move if I don't...
Occasionally I will not bother with the stabilizers if we are only in a spot for 1 night.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-07-2014, 02:05 PM   #7
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I don't use them at all. I put them out a few times the first year I had my trailer and didn't find any real advantage. Perhaps because it's just me and the two dogs. I was using my electric drill (on a fairly low torque setting, I might add), and found that once I had enough force to slightly reconfirm the door from easy opening/closing. So, I do open and close them to lubricate them a couple of times a year, but frankly, it's just one less thing to remember when I break camp....
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-07-2014, 02:30 PM   #8
m.hony's Avatar
2013 30' Classic
That's the difference-
You are by yourself.
With 2 people are in the trailer, 1 person walking will shake the other person in bed or on the couch-
If I ever end up by myself I will probably not bother, either.
I try to walk softly. Other people do not. Other people "lumber" or "stomp" with heavy feet.
TAC #MS-10
Airforums #70955
Stabilizers Pluribus Repairing/Replacing Floor &/or Frame 5 08-06-2013 05:40 PM
Do You Store with Stabilizers Up or Down? 10Smiles Jacks, Stabilizers, Lifting and Leveling 22 06-13-2013 01:01 PM
better stabilizers? Gringo Jacks, Stabilizers, Lifting and Leveling 23 10-06-2012 03:05 PM
Stabilizers mshamilton Jacks, Stabilizers, Lifting and Leveling 2 01-21-2012 10:33 PM
Steering Stabilizers LaCajun Land Yacht/Legacy Motorhomes 2 01-15-2011 10:32 PM
