Need BAL-Jack to replace the original 81
Anyone know which BAL-Jack to use on an 81 model Airstream. It has an extended shaft on it. I just busted one of mine and the shaft is rung off. Looks like I might need a new one. The original has two holes on the outside end and one at the tip. I only need one of them. Or I could use a new screw shaft for mine or a used one if the rest of the jack is toast. I bent mine but I can fix that part. The shaft is a little harder to fix.
Perry
