Originally Posted by jmhansen
Is there a way to just raise the axles a little?
Empty the trailer. If axle suspension is good, yes, it may rise, a bit.
If you didn't replace axles during rebuild, it may be time.
You can get axles with more initial "down angle"... And perhaps better load carry. But the AS frame will be the same. Too heavy a suspension will make the ride rougher. That will shake more inside he AS... And that loosens rivets, Screws, etc.
Hope you figure out the problem soon.
Oh, do not put the little "rollers" on the stern... The upward force there can damage your shell and the connection to the frame.
