Old 06-27-2007, 08:44 PM   #1
Vince & Virginia
Towster's Avatar
1969 21' Globetrotter
Riverside , California
Is my old jack welded on?
After 7 years of cranking in 100+ degree southern california heat, I just bought a new electric jack for our 1969 Globetrotter. Got all my tools out, got the old bolts and nuts off, looking good . . . but it won't come out.
Fine, it wll just take a little more persuading, some penetrating spray (not WD40), and a lot of whacking with a rubber mallet. It still won't come out. I know I've read accounts that some manual jacks have to be "de-welded". Is mine one of the those? And if so, anyone in the Riverside area interested in helping me tackle this?
Virginia <---- provides cold beer to helpers
Towster is offline   Reply With Quote
Old 06-27-2007, 11:03 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Doesn't look welded from the pictures. Probably just stuck. You might try setting the weight of the tongue on it using a block (4x4)underneath and some liquid wrench and a few blows downward on the tongue with a sledge. If it is welded it would be under the top plate but you would be able to see it-welds can't be hidden.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-28-2007, 07:57 AM   #3
Central , Mississippi
Put some wooded blocks under it and krank down the jack. It should force it's self out the top.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 06-28-2007, 07:36 PM   #4
Vince & Virginia
Towster's Avatar
Smile Victory!
Thanks for the advice . . . .
Using the extend the jack method, I got out my trusty sledge hammer and had a go at it. (In the 100 degree sun - what was I thinking?)
After about 5 resounding thunks, it budged about a quarter of inch. (There was much hope and joy in that quarter inch.) Another 15 whacks and it was out of there. Rapture!
Here's some photos of the results. Also replacing the coupler latch, spring and spoon. (Anyone have advice?)
Virginia <--- drinking the beer herself
ID:	40040 Click image for larger version
Old 06-28-2007, 07:43 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Towster - nice work. No advise on the coupler replacement but need to do the same - mine is exactly like your old one. Let us know what you used and how difficult it was to install please.
Old 06-29-2007, 07:05 AM   #6
I said "wooded"? Where did that come from?
Congrats on the success-
I'll have a beer tonight to celebrate.
Old 06-29-2007, 07:20 AM   #7
Retired.
. , At Large
Inland Andy has those parts in stock, give him a call.
Old 01-22-2008, 06:19 PM   #8
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
I replaced coupler on a '73 31' int sovereign this summer. With a little sweat, blood, an angle grinder, a wrecker bar and a good neighbor it was fixed. Throw in an Atwood heavy duty electric hitch with manual backup an she was good to go.
I junked two extension chords in the process, those sparks are pretty, but are flying red hot pieces of metal!
before
accident in waiting
tools for the job
almost there
hoorah. beer time
the shop vac went in there 6 ft and a lot of corn (rust) flakes came out
i spent $39.95 at trailer parts superstore then had a certified welder come to my house. whadya know, he lives three doors down and shares the same as$#*!e of a neighbor. we're now allies in da 'hood
don't forget to use some primer to cling to the virgin coupler, then some nice shiny aluminum paint to finish. I bought a new break away switch but never installed it. I sold the trailer and bought a vintage AS moho instead and plan to keep the moho for a decade or so. I will move back to a tt when the kids are grown all going to plan. Plans do change!!
elbundi is offline   Reply With Quote
Old 01-23-2008, 05:31 PM   #9
elbundi's Avatar
Leesburg , Georgia
If at first you don't succeed
here's the pictures that went missing from my earlier post. some kind of techno snafu made the attachments vanish. poooff, just like that
ID:	53063   Click image for larger version
ID:	53065   Click image for larger version
ID:	53067   Click image for larger version
ID:	53069   Click image for larger version
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
Where are the jack points? barbwire All Argosy Trailers 6 11-11-2002 09:52 AM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Jack Resync jcanavera 2000 - 2004 Safari 1 07-03-2002 10:45 AM
