Old 10-29-2006, 03:15 PM   #15
1976 25' Caravanner
Campton , New Hampshire
Most of the power jacks that I've seen also come with a manual crank handle if the motor or power should fail .
ticki2 is offline   Reply With Quote
Old 10-29-2006, 03:16 PM   #16
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
we've been talking about swapping out teh jack on our trade wind as well. the jack looks pretty loose on the top, and i don't want a similar fate to happen to OUR wind! a couple of questions...
do i HAVE to have a battery to run teh jack? can it not run off the blue charge line from the tow vehicle?
when it's plugged in, the blue line carries a current from the transformer in the rear. would that be enough to run the jack?
i could put a battery back in it, i guess... just need to figure out if this is going to be a couple hour deal... or an all-dayer?
jp
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 10-29-2006, 03:18 PM   #17
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Manual Tongue Jack Failure
Greetings Sugarfoot!
Originally Posted by Sugarfoot
. . . . Mine may not be so easy to replace. Instead of rivets like some of the vintages, I'm bolted and have the flange around the post welded to the tongue. The existing jack may have to be cut off somehow. I've read how someone on the forum knocked the setup from below with a hammer and displaced the weld, but my weld job looks pretty solid.
I suspect that you may discover something similar to what happened when Fogdall's replaced the original manual jack on my '64 Overlander. The original manual jack had a much smaller diameter post than the new electric models so both the top plate and bottom plate posed problems. I know that they cut off the bottom plate and welded in new material to mate with the new power jack, and if my memory serves correct, they also welded in a new top monting plate as well to insure that all was true and in safe operating condition. Unlike the original manual jack, the new power jack is bolted in so that it can be easily removed for service.
I am sure that you will be thrilled with the power jack!
Kevin
Kevin D. Allen
AIR #827
Old 10-29-2006, 03:27 PM   #18
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings ticki2!
That manual crank handle gave me some peace of mind until I had to use it. At least the one included with the power jack installed on my Overlander (the same one that was used on new Airstreams at the time), it takes five or more turns on the emergency crank to equal one turn of the old manual cranked jack. I have had to use mine in emergency mode twice, and hope to never have to repeat the experience.
I haven't had great any difficulty running mine when connected to the tow vehicle Bargman plug, but my dealer has run an extra-heavy charge line since I insist upon a 3-Way RV Refrigerator and always tow with the refrigerator switched to 12-volt DC.
Kevin
Kevin D. Allen
AIR #827
Old 10-29-2006, 03:35 PM   #19
1976 25' Caravanner
[quote=overlander64]Greetings ticki2!
That is true , it does take more turns , but then it turns easier . I just mention it so others don't think they are dead in the water because of a low battery or bad jack motor .
Old 10-29-2006, 03:36 PM   #20
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
That's good to know, I also had a heavy gauge charge line installed in the truck with a Modulite. Didn't know at the time if I was asking for overkill, but now there may be a payoff. Its good to know there is a manual override, but I'm not looking forward to that 5:1 work ratio!
Traveling With Elvis
life with a 1956 Sovereign of the Road
Aluminocentricity
Sugarfoot is offline   Reply With Quote
Old 10-30-2006, 04:48 PM   #21
Sugarfoot's Avatar
1960 24' Tradewind
1963 16' Bambi
OK, here's the scoop
After some creative knot tying, rigging, and duct tape (duct tape fixes all! ) I got the TW jack post secure enough to travel without bouncing on the pavement. Its down at Truck and Trailer USA, they've done well with my stuff before, cheaper labor than RV places and they "know" me now. I'm sure they are muttering under their breath, "Oh man, here comes that chick with the Airstream . . .", but they smile, give me credit for what I know, and always do anything I ask. They sell Atwood's, but a 3500 lb was $459. And it will only raise 7 inches per minute, go figure. I went to Camping World and picked up the Ultrafab 3500 tongue jack, raises 20 inches per minute, has a manual crank that inserts at the top instead of the bottom, and has a 6" extra drop on the foot. Plus, my research shows it to be relatively trouble-free compared to Barker's. Overkill with 3500 lb, but with the multi level terrain in my area I really need the adjustable foot. Jim, I would have loved to get one off eBay, but none of the refurbished have the adjustable foot. So I shelled out the extra bucks. I'm tired of dragging around the concrete block, so in the long run it will be worth it. Kevin, you're right. They will have to cut off the existing jack. Truck and Trailer will wire for power to the trailer 12V and the TV 7-pin. And they will save the old parts and try to determine why it failed. It should be ready later this week, so I'll let ya'll know how it turns out. Gee, I'll miss the vintage look of the manual jack but I'm looking forward to giving my aching shoulder a rest.
Aluminocentricity
Old 11-01-2006, 06:22 AM   #22
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
UltraFab 3500
Sugarfoot,
Congratulations on your purchase. I am sure you will be pleased with the Ultrafab 3500. We sell the Ultra fabs where I work on SOB trailers and they have proved very reliable.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 11-01-2006, 08:05 AM   #23
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
New Jack City
Sugarfoot you should be very pleased. The one thing I did do was remove the cap which covers the access hole for the auxiliary jack handle and put a bead of silicon sealer around the edge and reinsert. I was worried about a leak or the cap blowing off going down the road. I keep a 4 X 4 block in the bed of my truck to make adjustments, useful for other things also.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 11-01-2006, 08:13 AM   #24
Jim Clark's Avatar
Aux. Operator - Battery Operated Drill
[quote=ticki2]
Originally Posted by overlander64
Greetings ticki2!
I am now thinking Battery Operated Drill. I have to look at the fitting on my aux. handle. I always take my drill when I am on the road.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 11-01-2006, 08:50 AM   #25
Sugarfoot's Avatar
1960 24' Tradewind
1963 16' Bambi
Oh Jim, those are great ideas! I will certainly do that with the cap. Thanks! And the battery operated drill, that could just be the ticket.
Silverhobby, I'm glad to hear you haven't heard of issues with the Ultrafab either. That's the same thing the service tech at Camping World told me. Lots of others come back with problems, but only one Ultrafab in his experience. It was a wiring problem and was still under warranty.
Aluminocentricity
Old 11-01-2006, 01:18 PM   #26
Jacob D.'s Avatar
1964 26' Overlander
Alameda , California
My trailer came with an electric jack, but the battery ceased to operate while I was towing it back to California, which meant that when I got back at about 11pm I had the trailer in the driveway, the truck attached & blocking most of the street... and no way to lift the trailer off the hitch. Eventually I was smart enough to plug the trailer into a 110V outlet and the converter was working, but for whatever reason (dubious wiring, probably the same reason the battery died) the jack still wouldn't work. In the end, while digging for a manual jack in the back of a friend's car I realized that one of the obstacles I had just removed from his trunk was one of those battery-starter kits containing a... 12V battery. (I was not at my sharpest at that moment.) Hooked that up to the jack directly and eventually got it off the truck, but right then I did wish for a manual jack. Still I think when the wiring is done correctly I'll be glad of it.
Jacob D. is offline   Reply With Quote
Old 11-01-2006, 06:28 PM   #27
Sugarfoot's Avatar
1960 24' Tradewind
1963 16' Bambi
Originally Posted by jacobwellcom
. . . . Eventually I was smart enough to plug the trailer into a 110V outlet and the converter was working, but for whatever reason (dubious wiring, probably the same reason the battery died) the jack still wouldn't work. In the end, while digging for a manual jack in the back of a friend's car I realized that one of the obstacles I had just removed from his trunk was one of those battery-starter kits containing a... 12V battery. (I was not at my sharpest at that moment.) Hooked that up to the jack directly and eventually got it off the truck, but right then I did wish for a manual jack. Still I think when the wiring is done correctly I'll be glad of it.
Jacobwellcom, that doesn't sound like a pleasant experience. I'm hoping to avoid a similar situation by having the jack wired to work with either the TV or the trailer battery. But I'm concerned about what you say regarding jack wiring actually draining the battery. Does an electric jack normally draw on the 12V even when not being deployed or is this a problem only if wired incorrectly?
Aluminocentricity
Old 11-02-2006, 02:24 PM   #28
Jacob D.'s Avatar
1964 26' Overlander
The jack wouldn't draw current when it's not being used. In my case something else must have caused the battery to go dead. The wiring in my trailer has some issues.
Service manual wanted hill4th@gvtc Classic Motorhomes 1 09-02-2006 04:58 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
New tongue layout FrankR Cleaning, Stripping & Polishing 0 03-07-2002 08:51 PM
