Old 11-11-2018, 03:52 PM   #1
Yaphank , Arizona
Manual override crank for Atwood premier power jack
I have a 2017 Atwood premier where do I purchase the override crank handle for it since my jack is not working
scroon is offline   Reply With Quote
Old 11-11-2018, 04:07 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
The Amazon is your fiend....👍😂
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 11-11-2018, 04:08 PM   #3
Yaphank , Arizona
Can't seem to find it on there
Old 11-11-2018, 04:10 PM   #4
Yaphank , Arizona
Out of stock on Amazon
Old 11-11-2018, 04:13 PM   #5
Maybe this could work?
W. H. Auden
Amanamus
"Tahawus"
Old 11-11-2018, 04:29 PM   #6
2019 27' Globetrotter
Salem , Oregon
You can get a drill attachment. Try Amazon. Dave
NoResults is offline   Reply With Quote
Old 11-12-2018, 09:20 AM   #7
Watertown , Massachusetts
vice grip
Just get a large enough vice grip and attach that to the end of the post and spin the handle around to go up or down. There is nothing special about that tool.
sallye is offline   Reply With Quote
Old 11-12-2018, 09:37 AM   #8
Yaphank , Arizona
Old 11-12-2018, 09:37 AM   #9
2017 19' International
Highlands Ranch , Colorado
I bought mine from my AS dealer and tossed it in the toolbox to have on hand when necessary.
LeisaH is offline   Reply With Quote
Old 11-12-2018, 10:00 AM   #10
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
If it has a square configuration like the Barker jacks, then a twelve point 7/16” socket attached to 12” or longer extension will allow turning jack screw without taking propane tanks off trailer. The “included” handle from Barker was so short it would only do 180 degree swings before hitting propane tank enclosure.
Old 11-12-2018, 10:15 AM   #11
2014 27' FB International
Hooper , Utah
Atwood makes two different configurations of the handle crank. Make sure you are getting the right one!
Check your slow blow fuse which is located in the power line just below the power jack. The connection works its way loose and pops open all by itself. Make sure the fuse is not blown. I had mine come apart, and when there is no connections, the power jack does not work. A simple 30 cent part. A jack handle will cost you $35.00. I also purchased one for a backup and also a box of fuses. NAPA Auto parts stocks the fuses. AS will charge you an arm and a leg for the same part. NAPA is also cheaper than Amazon. As I remember the fuse is a 15 amp SLOW BLOW fuse.
albret is offline   Reply With Quote
Old 11-12-2018, 11:21 AM   #12
Yaphank , Arizona
The fuse looked the light on the jack works I think the fuse is 30 amp. Airstream just provided me with the socket not the crank handle when I took delivery of the trailer. When I put the socket on my drill it won't turn the nut.
Old 11-12-2018, 11:44 AM   #13
Glenn T's Avatar
2011 20' Flying Cloud
Lemont , Illinois
Before you buy anything, take a look at the jack in your tow vehicle. When my Barker jack stopped working, I found that the jack handle in my 2012 Toyota Tacoma used the same size square fitting as the Barker.
Glenn
Glenn T is offline   Reply With Quote
Old 11-12-2018, 11:55 AM   #14
Yaphank , Arizona
Is the Barker the same as an attwood
Atwood Premier Performance Series Power Jack w/ Robofoot KJRitchie Jacks, Stabilizers, Lifting and Leveling 4 08-01-2016 07:31 AM
Does this jack have a manual override? NicheVintage Jacks, Stabilizers, Lifting and Leveling 2 01-16-2010 11:00 PM
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 09:19 AM
Electric Tongue Jack Manual Override overlander64 Jacks, Stabilizers, Lifting and Leveling 10 05-07-2009 09:22 AM
Can you get a manual crank head for a power jack? JimGolden Jacks, Stabilizers, Lifting and Leveling 2 08-05-2007 05:00 PM
