Old 11-21-2018, 02:17 PM   #29
2017 25' Flying Cloud
Lawrenceville , Georgia
I called Airstream parts dept. They supplied the following P# 400961-02-100.
I ordered one from the my local GA dealer. 20 bucks. [ 2017 Flying Cloud ]
TANZER099 is offline   Reply With Quote
Old 11-21-2018, 03:33 PM   #30
BoscoMN's Avatar
2015 19' Flying Cloud
Rosemount , Minnesota
I just got done spending a couple of nights on the internet looking for a replacement for the original Atwood crank tool to no avail. I found one that is close but is a little bit larger in diameter. I am going to go to our Airstream to see if this crank handle will work. It is slightly wider in both the interior and exterior diameter than the socket tool that Airstream supplied with our 2017 25' FC.
A6E23032 23032 BAL RV Products/ Adnik Trailer Stabilizer Jack Stand Crank For $10.54 x 1
Got it from rvautoparts.com
If it mechanically will work with the jack's drive shaft then I may have to open up the plastic cover's access port to make it fit.
I will post my results on Friday.
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 11-23-2018, 07:19 PM   #31
BoscoMN's Avatar
Sadly the crank in my previous post is just a bit too big to fit into the metal drive shaft within the tongue jack. I will look into milling out an adapter so the hand crank will work with the socket provided by Airstream.
2018 F-250 6.2L Gas
Old 11-23-2018, 07:22 PM   #32
Yaphank , Arizona
Colonial airstream sent me the crank that fits the jack
scroon is offline   Reply With Quote
Old 11-24-2018, 04:47 PM   #33
BoscoMN's Avatar
Was it a socket that requires a wrench or was it a hand crank? I'd love to be able to buy one like Atwood previously had sold instead of having to build one up myself.
2018 F-250 6.2L Gas
Old 11-25-2018, 05:44 AM   #34
Power jack hand crank
AIRSTREAM P# 400961-02-100 is the hand crank with the socket welded on the end. PM me with your e mail address and I'll send you a picture. My AS dealer had to order the part. He received it in about a week. So it must be an AS stock item.
Old 11-26-2018, 05:38 PM   #35
BoscoMN's Avatar
Hoping to be able to purchase a crank like TANZER099 was able to. Meanwhile I took apart a broken down drill and cut off its chuck and mounted it onto the BAL hand crank that was too big to fit on to the jack. Looks like it should work - I'll give it a test next visit to the Airstream.
2018 F-250 6.2L Gas
Atwood Premier Performance Series Power Jack w/ Robofoot KJRitchie Jacks, Stabilizers, Lifting and Leveling 4 08-01-2016 07:31 AM
Does this jack have a manual override? NicheVintage Jacks, Stabilizers, Lifting and Leveling 2 01-16-2010 11:00 PM
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 09:19 AM
Electric Tongue Jack Manual Override overlander64 Jacks, Stabilizers, Lifting and Leveling 10 05-07-2009 09:22 AM
Can you get a manual crank head for a power jack? JimGolden Jacks, Stabilizers, Lifting and Leveling 2 08-05-2007 05:00 PM
