Old 11-13-2018, 06:38 AM   #21
jamieb1086's Avatar
2016 25' Flying Cloud
Selbyville , Delaware
Oops sorry about $32 for the jack handle and the fuses. And when this one goes it’s on tosomethjng more heavy duty!
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Watchung NJ Unit
jamieb1086 is offline   Reply With Quote
Old 11-13-2018, 07:22 AM   #22
2010 25' FB Flying Cloud
Davenport , Iowa
The original, and two replacements all shorted out. Blown fuse. I found moisture/water was getting in through the level on top of jack. I now keep the jack covered with bag I got from Amazon.
As for the tool for manual operation, I got a 12 inch extension and use it in conjunction with tool supplied. No longer does the LP tank cover get in way.
Airtandem is offline   Reply With Quote
Old 11-13-2018, 07:30 AM   #23
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Take the several screws that hold the cover on and check that the wires have not come off their clips. Happened to me the day I brought the trailer home from the dealer. Simple fix.
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 11-13-2018, 08:42 AM   #24
Yaphank , Arizona
Wow they should give you the new Jack's for free
scroon is offline   Reply With Quote
Old 11-13-2018, 08:43 AM   #25
Yaphank , Arizona
Mine was working than stopped as I was extending it.
Old 11-21-2018, 10:10 AM   #26
2011 28' International
Cedarburg , Wisconsin
I bought a spare handle from Dyers. Mine was a Barker jack. Link is: http://www.dyersonline.com/barker-hi...nk-handle.html
I add an standard socket extension so I can avoid the propane tanks.
gjhathaw is offline   Reply With Quote
Old 11-21-2018, 11:05 AM   #27
2016 30' Classic
Victoria , British Columbia
When I went to buy a crank for our Atwood 4000 jack, I purchased an “off the shelf” crank from Camping Hell. The diameter of the drive end was slightly too large to fit into the opening. I subsequently purchased a socket that had a smaller diameter that fit into the opening. If you purchase a genuine Atwood crank, there will likely be no problem. But be careful if purchasing a generic slotted head crank, and test it before driving off into no mans land to drycamp.
Camr is offline   Reply With Quote
Old 11-21-2018, 11:57 AM   #28
Mollysdad's Avatar
My Attwood 4000 (2017) came with a handle. It was in a cardboard box in the closet.
The bad news was when I needed it, I couldn't budge the jack with it. Up, yes; down, no.
You might try taking the weight off your jack using the TV jack and see if that allows it to work again.
My handle was a small square end on a crank.
Old 11-21-2018, 02:17 PM   #29
2017 25' Flying Cloud
Lawrenceville , Georgia
I called Airstream parts dept. They supplied the following P# 400961-02-100.
I ordered one from the my local GA dealer. 20 bucks. [ 2017 Flying Cloud ]
TANZER099 is offline   Reply With Quote
Old 11-21-2018, 03:33 PM   #30
BoscoMN's Avatar
2015 19' Flying Cloud
Rosemount , Minnesota
I just got done spending a couple of nights on the internet looking for a replacement for the original Atwood crank tool to no avail. I found one that is close but is a little bit larger in diameter. I am going to go to our Airstream to see if this crank handle will work. It is slightly wider in both the interior and exterior diameter than the socket tool that Airstream supplied with our 2017 25' FC.
A6E23032 23032 BAL RV Products/ Adnik Trailer Stabilizer Jack Stand Crank For $10.54 x 1
Got it from rvautoparts.com
If it mechanically will work with the jack's drive shaft then I may have to open up the plastic cover's access port to make it fit.
I will post my results on Friday.
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 11-23-2018, 07:19 PM   #31
BoscoMN's Avatar
Sadly the crank in my previous post is just a bit too big to fit into the metal drive shaft within the tongue jack. I will look into milling out an adapter so the hand crank will work with the socket provided by Airstream.
2018 F-250 6.2L Gas
Old 11-23-2018, 07:22 PM   #32
Yaphank , Arizona
Colonial airstream sent me the crank that fits the jack
Old 11-24-2018, 04:47 PM   #33
BoscoMN's Avatar
Was it a socket that requires a wrench or was it a hand crank? I'd love to be able to buy one like Atwood previously had sold instead of having to build one up myself.
2018 F-250 6.2L Gas
Old 11-25-2018, 05:44 AM   #34
Power jack hand crank
AIRSTREAM P# 400961-02-100 is the hand crank with the socket welded on the end. PM me with your e mail address and I'll send you a picture. My AS dealer had to order the part. He received it in about a week. So it must be an AS stock item.
Old 11-26-2018, 05:38 PM   #35
BoscoMN's Avatar
Hoping to be able to purchase a crank like TANZER099 was able to. Meanwhile I took apart a broken down drill and cut off its chuck and mounted it onto the BAL hand crank that was too big to fit on to the jack. Looks like it should work - I'll give it a test next visit to the Airstream.
2018 F-250 6.2L Gas
Atwood Premier Performance Series Power Jack w/ Robofoot KJRitchie Jacks, Stabilizers, Lifting and Leveling 4 08-01-2016 07:31 AM
Does this jack have a manual override? NicheVintage Jacks, Stabilizers, Lifting and Leveling 2 01-16-2010 11:00 PM
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 09:19 AM
Electric Tongue Jack Manual Override overlander64 Jacks, Stabilizers, Lifting and Leveling 10 05-07-2009 09:22 AM
Can you get a manual crank head for a power jack? JimGolden Jacks, Stabilizers, Lifting and Leveling 2 08-05-2007 05:00 PM
