Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 06-18-2003, 01:36 PM   #1
montanaandy
montanaandy's Avatar
Profile:
Manual Jack Broken - Best Elec. Jack?
We brought the AS home after having some new equipment installed and found that the manual jack does not work anymore (gears feel stripped - it won't raise or lower at all). We hauled it in to the local RV specialist and I need to have them replace the jack (among other repairs). I would like to switch over to an elec. jack but have read some posts about problems with certain elec. jacks/brands. What would those of you out there with elec. jacks recommend? Thanks, Montanaandy
montanaandy is offline   Reply With Quote
Old 06-18-2003, 10:44 PM   #2
LLB21
LLB21's Avatar
Profile:
The Barker H&H Super Jack is a good one. It holds up good.
Louie
LLB21 is offline   Reply With Quote
Old 06-19-2003, 06:12 AM   #3
Gunnyusmc
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 56
Smile Elec Jack
I also have a Barker H&H and its been great. Recomended by my Airstream dealer.
Gunnyusmc is offline   Reply With Quote
Old 07-09-2003, 08:11 AM   #4
uucal
Profile:  2003 25' Classic
North Ogden , Utah
The previous responders are right. The Barker is a good unit. It is presently used by Airstream. You can also find the same units in Camping World
Cal Hansen
uucal is offline   Reply With Quote
Old 07-09-2003, 12:38 PM   #5
Silvertwinky
Silvertwinky's Avatar
Profile:  South Shore , Kentucky
I too had to change the jack and I chose the Barker HD!
It fit right in place with only one minor problem. I chose to remove the "Excella" name plate from the front of the gas tank cover, it was pushing against the back of the jack just a little. I believe if I had installed it facing the side it may have cleared it.
Other than that it works great and it fit into the same holes without a problem.
Purchasing it at a trailer sales of “SOB” though, the only thing I didn't like was the fact that they only had white. However, after saving about $300.00 from what I was quoted at an Airstream Dealership for a replacement jack, I was happy with the white!
Visit our church on the web!
http://www.southshorecog.org/
"A safe camper is a Happy Camper"
Bill & Donna
Air Forums Member # 2360
Silvertwinky is offline   Reply With Quote
Old 07-09-2003, 02:42 PM   #6
montanaandy
Profile:
Replacing Manual Jack W/ Elec. Jack
Thanks for the responses. It appears that the Barker is the recommended unit, hands down. Is this something that I can install myself (somewhat handy) or should I have the RV dealer/service center install it?
Montanaandy
Old 07-09-2003, 03:09 PM   #7
drboyd
drboyd's Avatar
Profile:
It's three bolts and two wires max...
...the way I understand it, so I'm guessing you can do it yourself. The critical part will be correctly supporting the trailer tongue while you're playing around underneath it. Please be safe on that deal!
Old 07-09-2003, 06:40 PM   #8
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings Montanaandy!
I don't know whether you will run into the same problem with your '79 that my mechanic ran into with my '64 Overlander. The new power jacks are much larger in circumference than the orginal manual jack, and the way that the mounting was designed on my '64 welding was required to make the modifications necessary to fit the new Barker HD jack to the tongue of my '64 Overlander - - the new jack also had a different attachment bolt pattern as well that required drilling new holes.
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 07-10-2003, 04:53 AM   #9
Silvertwinky
Andy,
When I started to replace mine, I thought it was going to be a fairly difficult job but as it turned out it was much easier than what I had anticipated. Of course as drboyd stated make sure you have the tongue supported safely.
I suspect that since your A/S is a 31'er that it probably had an electric jack on it at one time! If it did then I would think that the holes should line up ok and that you have a power supply also.
When I changed ours it only took about an hour or two to do it myself. If you are going to try and replace it yourself, I would recommend that you disconnect the battery first to avoid any problems while doing the wiring.
After securing the tongue, I disconnected the wiring then removed the three bolts which came out fairly easy. Lifted out the old jack and re-placed it with the new one, replaced the bolts and connected the wiring and it was finished!
The jack came with a washer that I used which helps to make a better ground. If the jack doesn't get grounded properly, it won't work.
It was that easy! However, as I mentioned in the earlier post it rubbed the name plate on the tank cover once I placed it back on. I think I could have avoided this if I had positioned the jack facing to one side instead of toward the front.
I also took the time to replace the brake away switch. I didn't like the looks of the older one so I thought it would be a good time for that. It was fastened onto a small plate which was attached with one of the bolts on the jack.
Bill & Donna
Old 07-10-2003, 06:33 AM   #10
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Support
Safest and easiest way to support the tongue while replacing the jack is to simply do it with the trailer hitched to the tow vehicle. That's what I did on my SOB. There was plenty of room to work.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Electric/Manual Jack Security Question docbluedevil Towing, Tow Vehicles & Hitches 1 11-01-2003 11:50 PM
Moving the camper without the front jack wheel Silvertwinkie Our Community 9 07-22-2003 06:46 PM
Jack for a 3 axle trailer dmreilly10000 Axles 2 01-07-2003 12:27 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
