Old 07-05-2010, 10:17 PM   #1
sound-silver's Avatar
1978 29' Ambassador
2004 25' International CCD
Moab , Utah
Low Profile Electric Tongue Jack?
OK, here's my random question. Is there a low profile electric tongue jack out there? Whenever the trailer is hitched I can't fully drop the tailgate on the pickup. The body of the electric tongue jack gets in the way (just barely) for the tailgate to swing all the way down. If the jack body was primarily underneath the tongue all would be great.
It's not where you are, but your reason for being there.
sound-silver is offline   Reply With Quote
Old 07-05-2010, 10:41 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I've never seen one. Their design is such that lowering the profile lowers the "throw," that is, the working distance over which the jack operates.
You've probably already explored alternative tailgates, like this: Pro-Net Tailgate Net - full size truck - Black - CargoGear Car and Truck Accessories
Depending on your weight distribution and anti-sway setup you may be able to get an extended shank for a little bit more clearance. This one is about 4" longer than standard:
Reese Weight Distributing Shank, 15,000 lbs. Draw-Tite 63970
The PPPPP and HAHA hitches are inherently longer too so if you're thinking of getting one that should solve the tailgate problem.
Old 07-06-2010, 01:42 AM   #3
_
Originally Posted by sound-silver View Post
...The body of the electric tongue jack gets in the way (just barely) for the tailgate to swing all the way down...
IF this issue is on the '04 trailer and depending on jack model...
the jack head can be rotated 1/4 turn.
((look for the 3 hex head retention screws at the base))
often by rotating the head to the SIDE enough clearance is gained 4 tailgate droppin'
cheers
2air'
Old 07-06-2010, 07:00 AM   #4
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Rotating the motor assembly worked for me. The Tundra tailgate would not clear otherwise. Very easy to do.
Steamy1 is offline   Reply With Quote
Old 02-10-2013, 08:23 PM   #5
1972 31' Excella 500
Mount Vernon , Is For Lovers
My previous response was moved so I will try again. Is it possible for you to extend your tow shank on your truck? My hitch shank has two positions that are about 1 1/2" apart.(lock pin choices)
Sylver Slypr is offline   Reply With Quote
Old 02-10-2013, 08:31 PM   #6
Kevin245's Avatar
Your thread is here. http://www.airforums.com/forums/f464...ml#post1259740
Eleanor Roosevelt
Old 02-10-2013, 08:47 PM   #7
Extending the shank may give desired clearance, however, it could open up different challenges as far as w/d is concerned.
Electric Tongue Jack nynick52 Jacks, Stabilizers, Lifting and Leveling 18 04-09-2018 12:47 AM
Tongue Jack..Electric vs Manual TankerIP Jacks, Stabilizers, Lifting and Leveling 9 05-29-2010 09:11 PM
Electric tongue jack help RVnDixie All Argosy Trailers 8 12-31-2006 08:54 PM
Electric Tongue Jack darryl97420 Jacks, Stabilizers, Lifting and Leveling 0 05-25-2006 08:57 PM
Electric tongue jack not extending ipso_facto Jacks, Stabilizers, Lifting and Leveling 5 03-25-2003 11:58 AM
