Old 05-20-2008, 10:39 AM   #1
Brow324's Avatar
2007 27' Safari FB SE
Scurry , Texas
lost my stabilizer jack speed wrench
Anyone know of a source for a new stabilizer jack speed wrench/crank?
Doesn't appear to be one of those items that the A/S dealers have in stock.
Left mine on the truck bumper and it's now on the highway somewhere! argh.
'07 27 FB - H.A.
Brow324 is offline   Reply With Quote
Old 05-20-2008, 10:58 AM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Cordless drill with a 3/4" socket.
On edit, you probably have the funky one with the dogs on each side - socket won't work.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-20-2008, 10:59 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
A 3/4" (sparkplug) socket is a decent interim alternative. Here's a work saver -- I bought an inexpensive chuck adapter so I could use it with a battery powered drill. That's not the complete answer. I still need the OEM speed wrench to tighten the jack support a bit when I set up and loosen when breaking camp.
5 meter Langford Nahanni
Old 05-20-2008, 11:22 AM   #4
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Most RV stores (Camping World, etc.) carry them, the 3/4" size is pretty common.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 05-20-2008, 11:50 AM   #5
altamont's Avatar
Tracy , California
I go along with CanoeStream. I bought a fairly cheap ($50) cordless drill with 2 batteries, the socket adapter and the socket. Using the hand unit is slow and tedious. I set the drill so that it has a torques setting that does not apply too much pressure (remember, they are stabilizers, not levelers). I get all 4 down (or up) in under a minute. Priceless when you are up and down each night.
altamont is offline   Reply With Quote
Old 05-20-2008, 12:28 PM   #6
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If you don`t want to spend the money on drill try Ebay,but sometimes the shipping will kill you. Dave
easyride is offline   Reply With Quote
Old 05-20-2008, 01:10 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I use a Craftsman brace type crank with a socket. Same idea as the factory toosel but has handles with bearings and is a lot easier to use. And you don't have to worry about dead batteries in an electric jobby.
Old 05-20-2008, 01:32 PM   #8
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Like Lumatic said: use an automotive speed wrench (autozone, kragen, NAPA, etc)> Plus you can use other sockets for other projects.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-20-2008, 02:12 PM   #9
Brow324's Avatar
Scurry , Texas
Great ideas! ...duh! I didn't realize it was a standard size...that makes it easy! I've got an automotive speed wrench, extension, sockets, AND a cordless electric drill with torque adjustment...and I just learned that they have replacement stabilizer speed wrench/cranks at Holiday World, which is right down the road from me!
'07 27 FB - H.A.
Old 05-20-2008, 03:59 PM   #10
2004 25' Classic
West Chazy , New York
Cordless drill motor works just great for me. I cut one end off of a ratchet extention and stuck an appropriate sized socket on the other end, tightened it in the chuck and "tada", a real time and sweat saver!
Ron
2004 Classic 25 - The Silver Sausage
2008 Silverado LTZ CC 2500 4x4 Duramax - Brutus
WBCCI 2623
romap is offline   Reply With Quote
Stabilizer (BAL) jack --loose nuts? Kistler Jacks, Stabilizers, Lifting and Leveling 7 09-16-2007 08:24 PM
Replacement stabilizer jack mikeandbecky Jacks, Stabilizers, Lifting and Leveling 4 08-29-2007 05:39 AM
Stabilizer Jack Installation uwe Jacks, Stabilizers, Lifting and Leveling 16 11-11-2004 05:39 PM
Stabilizer jack stuck Tinsel Loaf Jacks, Stabilizers, Lifting and Leveling 10 03-12-2004 11:43 AM
