Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 09-12-2006, 11:09 AM   #1
fanerd
Profile:  1973 27' Overlander
Bemidji , Minnesota
lifting a trailer
I would like advice on how to lift my trailer to work on the undersurface...ramps...jacks...or something else???
fanerd is offline   Reply With Quote
Old 09-12-2006, 01:08 PM   #2
Wabbiteer
Wabbiteer's Avatar
1972 29' Ambassador
Twin Mosquitos , Minnesota
May not be the best way but here's how I lifted mine - found some discarded 6x6 landscape timbers and cut them into a variety of lengths starting with 4 pieces at 18" for the bottom layer of the cribbing - I wish I'd gone longer but thats what I used.
I used four sets of cribbing timbers - two per side, one for a bottle jack behind the axles and a larger one for the frame between the axles.
With the hitch trailer jack wheel removed and post well supported I lifted each side six inches at a time, restacking and adding a 6x6 timber onto the stack between the axles to get a minimum height I could work with, then I leveled trailer w/ shims and removed jack cribbing. I may need to lift trailer higher at some point but as you see it has been okay so far.
I had some interference with cribbing when dropping the axles but nothing a little more crowbar action didn't fix - and also can not put the wheels on with cribbing in place, but I feel fairly secure the trailer isn't going anywhere..
Here is a picture of the Missus trying to decide where the axle graveyard will be...
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 19 12-12-2003 07:39 AM
Suggestion: Airstream trailer Forums (by Model & Year) hex Forum How-To's & Support 2 10-15-2002 06:38 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Trailer Life RV Campground Finder Pahaska Our Community 12 08-03-2002 08:45 AM
