03-06-2018, 09:32 PM
2018 30' Flying Cloud
Edgewater Park
, New Jersey
Lifting the trailer
I have read numerous threads about upgrading from 15' to 16' tires, the majority being positive.
I haven't read anything about having to lift your trailer. I'm not sure if that is something I would need to do. I just purchased a 30' FC and I'm considering upgrading the tries almost immediately.
I also read where someone kept the 15' and just upgraded the tires to Michelin. I know this has been discussed ad nauseam, but I'm interested to hear about others who have kept their 15' and they chose to upgrade the tires.
03-06-2018, 11:22 PM
2014 30' FB FC Bunk
Golden
The 30fc has dexter #11 axles and they make a lift kit that is about a 3” lift. Search here for a recent thread and YouTube for an informative but rather dangerous how-to. I will be lifting mine this weekend.
Good luck!
03-07-2018, 04:23 AM
2005 30' Safari
Montgomery
I stayed with 15” rims on our 2005 Safari bunkhouse, opting for the Michelin Defender LTX. The GVWR is 8400lbs on the trailer, I’d have to be within a couple hundred pounds of that to overload the tires. Our “ready for three weeks on the road” weight about 7400 lbs. (1840-ish lbs/tire). Max load for the tires is 2071 lbs after derating them for trailer use.
I did take the trailer through the Escapees Smart Weigh program last year, and can recommend it or something similar to you. Having individual tire loads for both truck and trailer not only helped me dial in a new hitch, but also gave me the data needed to be comfortable with my tire choice.
On the lift kit—it’s on my list, too. I’ve got Henschen axles, and the Dexter kit doesn’t work. It seems easy enough to make a kit, but I’ll admit to preferring an off the shelf option. It’s not a priority now, but will be cool when it happens. Post pics of your trailer after the changes!
Dave
03-07-2018, 05:40 AM
Peoria
Good luck!
What "safe" method do you suggest for installing a lift?
'24 Silverado 2500 Diesel 4x4 ZR2, 2018 FC 28W (Queen) Landmark Truffle, ProPride Hitch, 3" Dexter Lift, Centramatics
03-08-2018, 07:17 AM
2014 30' FB FC Bunk
Golden
Well, others will know more than I on a safe method, but the video of the guy lifting his 30' FC - just a pair of jackstands and nothing else to catch the trailer should a stand fall, thats the dangerous part. And he even mentions a former neighbor who's Mercedes came off the jack and onto the poor guy's arms in the video. Otherwise a fantastic how-to though!
As for me, I plan to do one axle at a time, and keep the wheels on the other axle.
03-08-2018, 12:39 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
ahh yes... we buy a trailer with a nice low center of gravity, that handles really well, and .......
never mind
03-08-2018, 01:48 PM
2007 22' International CCD
Corona
never mind
...then, as many others have noted, it no longer drags on moderate driveway slopes, has less likelihood of tearing off the dangly darn low-hanging drain plumbing, and STILL handles really well. A few inches taller does not seem to cause a perceptible change in handling...its all about improvements, as Wally noted.
I suspect If I loaded a raised AS with several crap-tons of massive stuff to full gross, all in the upper cabinets, it might be an issue, but I would hope our raised Airstreamer friends have better sense than that.
Now, if you jacked it up to the height I see on some SOB toy haulers and fifth wheel monster mansions on 6 wheels behind an F-150 around here, swaying as they go down the highway, bouncing all over the place, yes, you have an absolute point! I run away from those folks as quickly as I can, even when driving the car...not interested in participating in their fate!
03-08-2018, 02:21 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
I'm at 4000 miles this trip with a lifted 30', no difference in towing other no dragon arse.
03-08-2018, 03:10 PM
2016 28' International
2015 28' International
2013 28' International
Las Vegas
, Nevada
Modifying the factory axles by adding a lift kit will void the warranty on any AS, so some might have to wait until the warranty is done.
And no, rwsjms you do not need to raise the AS when upgrading to 16" wheels, they clear just fine!
03-08-2018, 04:19 PM
Senior Member
Sparks
, Nevada
Lifting the trailer
Not true! No effect on warranty.
03-08-2018, 06:53 PM
2004 31' Classic
Rock Hill
, South Carolina
We replaced our GYM tires with Michelin 235/75R15 XL five or six year ago and have had no trouble. Its time to replace tires again , the model we have has been replaced with new model the Defender LTX load range 109. My old ones are 108 so that is an upgrade. They also have a max tire pressure of 50 psi as versus to LT 16" tires of 80 psi making for a softer ride for the Airstream. The axles can be replaced with a different torsion arm angle. Our trailer is at Colin Hyde Trailer Restorations having new axles installed, 32 degree axles should raise trailer about one and a half inches. Hope this helps you and congratulations on your new trailer.
03-08-2018, 06:54 PM
2007 27' International CCD FB
San Diego
I upsized the tires on my 15" wheels AND added a dexter lift kit to my 27FB.
I kept the 15" wheels and went from 225/75/15 to 235/75/15s. This was when I first acquired the trailer which needed new tires immediately. The 235/75/15s are .6" taller in diameter, lifting the trailer 3/10ths of an inch. I wanted the taller tires for more sidewall and a gentler ride. And thought that was all the lift I'd ever need.
After trying to get the trailer dialed in for my SUV (Lexus Land Cruiser), that has 33" tires, and hydraulic suspension that does not droop with load, I realized I needed a serious drop shank to get the trailer level. Instead of that, I opted to lift the trailer to have it about match the ground clearance of my tow vehicle as I knew I wanted to visit off the beaten path boon docking sites.
The lift and tires have worked incredibly well. No ill dynamics to speak of and she tows straight and true. Even in extremely high winds.
03-08-2018, 07:47 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
You must have missed it.....the never mind part.
03-08-2018, 08:38 PM
2014 25' FB Flying Cloud
Des Peres
, Missouri
We just changed out our GYM 's with GY Endurance 15 inch
Haven't taken a trip yet but will report back after a 4000 mi trip in June
03-08-2018, 08:51 PM
Corona
Lifting the trailer
Nah, I was just in a mood to scribble a few thoughts on the forum about what I consider to be a fun subject
Hi Bob!
Just remember, “Harassment is like camouflage, it has to be continuous to be effective!”
03-09-2018, 04:41 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
W. H. Auden
TBC
03-12-2018, 11:26 AM
Edgewater Park
, New Jersey
Thank you, I verified all this with our dealer.
09-09-2018, 02:29 PM
Silverdale
Looking to do the same thing. Does anyone know of someone who could perform this upgrade in the Seattle area?
09-09-2018, 04:22 PM
Wolfwhistle
Margaritaville
, Banana Republic
The More We Explore also lifted a 23D (CB) with homemade blocks. It gave me confidence and I did mine.
It is fairly hard to do. Bolts are very tight and new bolts torqued at 140#. Hard to do considering where they're at. I welded the horizontal nuts into the blocks since I could see not way to get a wrench on those.
Bolts are 15/16" and you will need open end and deep well socket. I bought a heavy duty impact gun that made it easy to remove bolts. I also have 3/4" drive set. I bought the #11 kit from eTrailer.
The actual gain is 2-3/4". Another factor for some of us is the 5/8" gas line is in the way and has to be rerouted. The way TMWE did the 23D the line had clearance. I would not be comfortable welding the blocks to the axles like he did.
I am happy with the result. In fact, without doing something, the trailer is too low for my stock 4x4 F250 with the longest Blue Ox shank available. I am also going to lower the truck rear by 1.375" and that will make it perfect.
WW
Is taking it all with you, really getting away from it all?
10-24-2018, 07:32 AM
2020 30' Classic
Norman
, Oklahoma
Does anyone have a photo of what the wheel area looks like with the lift?
