Old 10-01-2015, 11:14 PM   #1
Durango , Colorado
Question Lifting the frame on a 19' Bambi to gain more ground clearance
I have been searching the forums for advice on gaining ground clearance on a 2007 19' Bambi. There are some older discussions but I can't find anything current. We live in Colorado and do a fair amount of camping in forest service campgrounds and also boon docking. I would like to lift my Dexter Axle 3" to get the waste water valve and under carriage higher off the ground. Has anyone done that modification lately and what are your recommendations and experience with this issue?
Ken
pkm123 is offline   Reply With Quote
Old 10-02-2015, 08:45 AM   #2
Mission , Texas
Sometimes search works better from outside of the forum, like using Google.
Here's a thread ...
http://www.airforums.com/forums/f437/dexter-torsion-axle-lift-kit-102393.html
nrgtrakr is offline   Reply With Quote
Old 10-02-2015, 09:00 AM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You got it the dexter kit...
Old 10-02-2015, 09:13 AM   #4
Ken
Ken.
There are many ways to raise the trailer for more ground clearance.
One of the easyest ways is to add a steel channel to the bottom of the frame, then welding the axle to that new extension. In that way, you can choose what ever clearance you want, on up to about 12 inches, or more.
However, keep in mind that the square axle tube cannot be raised.
The only way you can raise the axle tube is by changing out the axle, for one with a higher startying angle. But, when you do that, you are limited as to the starting angle. Anything beyond about 32 degrees, will cause more shock to be imposed on the entire coach, when the coach hits a pot hole or bump.
Old 10-04-2015, 05:54 PM   #5
2013 16' Sport
Boulder , Colorado
Another related thread here:
http://www.airforums.com/forums/f295...ay-138548.html
Seecue is offline   Reply With Quote
Old 10-04-2015, 11:14 PM   #6
Durango , Colorado
Thanks everyone for your comments and advice.
Ken
Old 10-06-2015, 07:07 PM   #7
Durango , Colorado
By the way, does anyone have 1/2 of the Dexter #12 Torflex Kit (K71-725-02) for dual axels for sale to lift the single axle on my 19' Bambi?
Ken
How to gain more clearance amaier7771 Axles 130 02-24-2018 06:13 PM
Gain more countertop space Wayne&Sam Airstream Lifestyle 20 08-20-2015 11:55 AM
Lifting an Airstream? Ground clearance? cmmorsey Jacks, Stabilizers, Lifting and Leveling 5 06-17-2014 01:49 PM
19' Bambi ground clearance/"lifting" Glenn Hansen General Repair Forum 13 09-16-2007 07:11 AM
