Old 06-04-2019, 06:22 PM   #1
2019 25' International
Providence , Rhode Island
Question Lifting one axle tire set for zero turn?
I have no choice but to zero turn the trailer. I bought two 1500 pound wheel dollies to lift the middle axle up....but that doesn't have what it takes to lift it up.....I thought it would be enough for easy rotation.
The wheel dollies work as I was able to lift a Saturn Vue with them...so its not the dollies, just more weight than I expected.
I am not in the position to remove the tires to make the turns every time....anyone have any ideas on how I can do this?
kittmaster is offline   Reply With Quote
Old 06-04-2019, 06:25 PM   #2
2007 27' International CCD FB
San Diego , California
Need a bit more information. What kind of trailer and how many axles is this trailer you're dealing with? Picture could also help.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 06-04-2019, 06:48 PM   #3
Sorry, 25RBQ International Serenity.....dual axle.....its a 300 foot driveway where I turn around at the end of it......backing up is not an option and I have to manually turn it around down there once it is pulled in.
I'll try to get pics tomorrow.....but hopefully enough info to go on.
Chris
Old 06-04-2019, 06:52 PM   #4
What are you doing to try to turn in once an axle is up on dollies? How are you lifting/pivoting the trailer/tongue?
Old 06-04-2019, 06:54 PM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Sounds like you need a turntable like they use for locomotives.
AlinCal is offline   Reply With Quote
Old 06-04-2019, 06:58 PM   #6
Using an Airtug power dolly to move it around very effectively. The issue is the inner tires "drag" as the turn is made.......while others have posted they've done this for years with no issues......I believe them, but by lifting the inner wheels, it will make the turn a LOT easier since there won't be any drag from the inner tires.
Old 06-04-2019, 06:59 PM   #7
That would be neat......and "cheap" .....LOL.
Old 06-04-2019, 07:12 PM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
What is the driveway surface, at the location you are trying to pivot?
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 06-04-2019, 07:13 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Wow! That’s a tough one. Got what it’s worth, I would simply turn the trailer as required by using the Airtug. You can always move the inside tires to the outside position to balance things out.
Old 06-04-2019, 07:47 PM   #10
Long Island , New York
Originally Posted by kittmaster View Post
......backing up is not an option . . .
Chris, could you please explain why? If you can tow the trailer down the driveway, why can't it be backed down . . . somehow?
Is it possible that you have made certain assumptions -- put blinders on, in effect -- which are not 100% accurate?
Are there issues with the slope of the driveway, sharp turns, gravel/slippery surface, and so forth?
Please explain, and add photos/drawings to clarify why you could not back down the driveway . . . towing. Maybe with a different tow vehicle or commercial hauler?
Peter
Old 06-04-2019, 08:28 PM   #11
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
If I understand....a bottle jack under the frame between the wheels will very effectively lift both wheels. The trailer weighs approximately 6000 on the wheels. So your wheel dollies might be strong enough. However the way these things are labeled you need at least a 6 ton bottle jack and bigger is better. You also need a “saddle” for the jack to keep it under the frame.
Old 06-04-2019, 08:51 PM   #12
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley , Georgia
Just thinking outside the box a little. What I used to do to set caster on my race car is put 2 plastic bags on top of each other with some grease between them. Would let the tire slide and not bind up. Didn't have quite as much weight, but might be an inexpensive experiment. Not sure how smooth the driveway is. If not finished, a larger plate of some kind with a smaller plate under each wheel. Just a thought.
Mike S. is offline   Reply With Quote
Old 06-05-2019, 05:07 AM   #13
Normal asphalt, no dirt, sand or gravel.
Old 06-05-2019, 05:19 AM   #14
dznf0g's Avatar
Oswego , Illinois
How much back and forth room do you have with the tug while making the turn? Each time you go back and forth, with a right and left motion with the tug releives the sidewall pressure on the tires.
-Rich-
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Zero turn with my Airstream Devanan Towing, Tow Vehicles & Hitches 27 01-11-2019 10:39 AM
AimZero- zero grid, zero feul, zero discomfort, zero nonsense. greenlinks Off Topic Forum 14 01-03-2014 08:13 PM
Zero - Snow - then BELOW ZERO bugnot1 Winter Living 43 02-11-2011 09:02 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
