12-11-2018, 02:38 PM
Bryant
, Arkansas
Lifting my triple axel limited?
Hello friends, I was following the thread about lifting a double axel with a Dexter lift kit.
Has Anyone raised a triple axel airstream?
I am very interested in hearing from anyone who has raised a triple axel and how it worked out, any special problems encountered etc.
I have a 2011 Classic Limited triple axel and I am considering that upgrade.
Any experiences or comments will be appreciated.
Thanks, Bill
12-11-2018, 04:01 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
I asked this same question just a few days ago in a different thread. (I suppose the one you mention)
The only thread I am aware of for a triple axle change is this one, that does not talk about lifting >
http://www.airforums.com/forums/f437...rs-143529.html
ps: I sent a request for information to Dexter asking if they have a kit for a triple axle. There has been no response.
Alan
12-11-2018, 04:48 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
I would believe no I’ll consequence would come from lifting you tri-axle trailers. I have towed my double axle unit 20000 miles without any noticeable difference in handling. I can see a huge benefit to your 34’ trailers in the rear clearance.
I did a custom 3” lift.
Dexter only sells sets of 4 lift blocks, but you can buy two sets and sell the extra pair to a Bambi owner for 1/2 the cost of a kit. No problem
12-11-2018, 07:48 PM
1999 34' Excella
Hillsboro
One look how things bolt up, no way I would do that. I would not buy one that had been lifted because “I” believe the change would add more flex and torsional stress to the frame.
When I replace ours I did add some “downturn” / angle down. That had effect of lifting the AS about 3.3”. This effect was due to the change in angle, 3500# axles replacing of worn standard 3200# axles. I measured at the axle to fender lip and the step height from ground. After 3 years this past November 2018, the axles have “settled” about 3/16” as best I can measure.
I know that is more than you asked, but please take it as only my opinion based upon my expand observations.
Peace and Blessings..
Channing
WBCCI# 30676
12-11-2018, 08:07 PM
Overkill Specialist
Dadeville
, Alabama
How would it add more stress. ( I’m really asking, not being smart butt) The lift block bolts the the frame with the same holes the axle did and then the axle bolts to the bottom of the block. The block is resting in and on the frame and the axle is simply dropped down the thickness of the lift block. The axle can not torx/ flex under Torsional stress because the block is in the way, and would have to be crushed in order for that to happen.
The side force would be no different than stock and the lift blocks can not torque that way because the axle mount is welded on the inward and outward sides.
12-11-2018, 08:39 PM
2007 27' International CCD FB
San Diego
As an engineer, I don't believe lifting a 3 axle trailer to materially be any different form a 2 axle trailer, or a 1 axle trailer for that matter.
There shouldn't be materially more flex/stress to make any difference here. So long as the the axle blocks are matched to the axle capacities (Dexter makes slightly different blocks for different capacity axles), i.e. #10, #11, #12 and so on.
A 3" lift also is more than it would sound. Not that this is a negative, but a 34' trailer would have a lot more "presence" and look more imposing with a lift. That I surely noticed even with my 27FB.
12-12-2018, 12:47 AM
Salem
, Oregon
Hi, on a 34' trailer being lifted, I could see some frame flex. Instead of six lift brackets, I think one three axle lift bracket per side [two total brackets] would be the way to go.
Actually all axle lift brackets should be only one piece per side whether your trailer has one, two, or three axles.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
12-12-2018, 05:02 AM
Bryant
, Arkansas
Thanks to you all for your input.
I would feel pretty comfortable installing a pre-manufactured lift kit but am hesitant to try to make my own. I can see how there might be more side to side stress because of leverage but agree that frame flex should be exactly the same with or without the lift. Am I missing something?
Looking forward to seeing more thoughts from you.
Thanks again, Bill
12-12-2018, 06:49 AM
2000 25' Safari
Davidson County
I think stress on the frame from adding 6 brackets on a 3 axle would be substantially different than it is on a single or tandem when the trailer was turned sharply, like pivoting when backing into a parking space. My trailer will pivot on the center axle and slide the tires sideways on other two. The force on the rear axle would be opposite the front when this happens. Thinking of the forces on the tires, leverage will increase the horizontal force applied to the frame during this type of move. (by increasing the length of the lever beam by ~3")
I think I'm going to agree Channing (post #4) and not add the brackets to my 34' trailer. Instead, I'll add some down angle when I replace the axles. (and keep a few $ in my pocket )
Alan
12-12-2018, 02:11 PM
1976 31' Excella 500
Chappell Hill
I lifted my 31' and have noticed no difference in pulling other than ground clearance is better.
Since AS axles are bolted directly to the frame whether lifter or not the axles can't flex or cause frame flex.
All the flex is, I'd guess you'd say "outward" of the rubber isolation/flex "springs" things and into the spindles, spindle arms, and tires.
12-12-2018, 03:17 PM
Overkill Specialist
Dadeville
, Alabama
3” Lever would if it existed increase the torque force by 25% (Right?).
Torque measured in foot/lbs = 1 lb of force, 1 foot away from the axis point? Adding 3” the the “lever” would increase the force 25%?
I’m not an engineer, I’m asking......
If that’s correct, and if there is an appreciable amount of force the added force would be low.
12-12-2018, 05:41 PM
2000 25' Safari
Davidson County
I'm asking too, since I don't know>
How much force does it take to slide two tires on an axle sideways (not roll) on the ground/pavement/etc., while at the same time the tires are bearing ~3,000 lbs per axle?
I'll guess the two opposing forces, front and rear axle, on a three axle trailer would be measured in hundreds, maybe thousands, of foot pounds.
Alan
12-12-2018, 07:21 PM
San Diego
3" is not a big deal and well within the structural margins that exist in any design like this.
To the person considering adding down angle. That is not necessarily the magic bullet either. Increased down angle means the suspension arm is no longer operating in its optimal stroke. With every suspension stroke now causing dramatic forward to aft motion and bump steer in the tire as a result of the arm operating in a more extreme angle. This would certainly cause more dynamic impacts than a block lift. And practically the same leverage loads as a block lift.
Personally, thinking as an engineer, I'd do the dexter block lift and call it a day. Block lifts are done all day long even by OEMs in just about every type of vehicle/trailer. That proud standing F250 or SOB... block lift.
12-14-2018, 12:02 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Colin Hyde, axle expert, of Plattsburg, NY, says to go with more down angle rather than lift blocks because of frame flex. However, I would think that a single tube on each side for all three axles would make the frame stiff enough to handle the added turning stress. Just my opinion as I contemplate how to lift my 35' slideout. I have one of the last trailers built with Henschen axles.
guskmg
12-17-2018, 03:41 AM
1999 34' Excella
Hillsboro
Up front... it is your Airstream. Let the next owner worry about it. Nah... nobody dies that!
I increased down angle and weight carry rating in our new axes. I got the lift I expected with less stress.. pardon the pun.
If the axles are mounted to a single structural unit which encapsulates the frame... that might be fine... the axles may act as a “trolley” of sorts. To make that work you steer the trolley with a lead or put it on tracks. So the former is the only option for our trailers. That means the frame is the lead, just like from the factory.
When you extend the arm of moment, loads quickly amplify. We all agree.
However, Dexter doesn’t recommend 3 of their duratorque axles in one trailer... perhaps the manufacturer transferred the risk to the Airstream folks.
If I were to lift, I would build a truck like a train car but no pivot. The mounting can and should be discussed of course.
Channing
WBCCI# 30676
06-23-2021, 07:39 PM
NK
, Rhode Island
it's been a long time since you posted about lifting your 34' excella-- I was wondering if you had any tips
