Old 10-04-2012, 05:35 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by KYAirstream View Post
What's the problem with using concrete blocks, unless of course they are hollow..... Seems like placing the jack stands on solid concrete blocks would be more than adequate?
Timber weighs about 35 pounds per cubic foot. Concrete weighs 150 pounds per cubic foot. So, two 212 boards cut 12" long (for a total of 0.33 cubic feet) weighs ~10 pounds. A concrete block the same size would weigh ~50 pounds, and adds nothing at all to the stability of the trailer in exchange for that extra weight.
Concrete would be more than adequate, but so would the lumber, and the lumber is (1) much easier to handle and (2) cheaper unless you already have half-a-dozen concrete blocks lying around.
Handy hint, if you're worried about termites, wrap the boards all-around in metal or plastic screen-door mesh first. That should keep the termites from snacking on your cribbing.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
5 year search, we got it! Sodbust 1972 Overlander 23 03-24-2012 08:34 PM
Wow!!! BUY IT NOW $145,000 toastie Vintage Kin 33 03-11-2012 04:45 PM
Well -- It's been a while! gypsychris Interior Restoration Forum 53 03-10-2012 10:25 PM
LED Retrofit issue and reading light front assembly rodsterinfl Lights - Interior & Exterior 0 02-28-2012 05:21 AM
