Hrmmm... it’s on my list on Amazon too... need to just pull the trigger on this and make it happen before I wish I had ..
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
I have been using LevelMate Pro for a year and a half and could not imagine traveling without it. My sensor is mounted next to the sink on my 16’ Bambi. I am traveling solo, so use it to find the most level spot in the site while still in my TV! Saves a lot of leveling later and especially useful when I don’t want to unhitch for just one night, when in travelng mode. I also use it to “remember” the exact spot that I raised the hitch up to when unhitching, to make it faster when hitching up to leave again later on. Just a heads up, be sure to check your batteries regularly! The sensor goes through batteries regularly - about 4-5 months for me! I always check it before I am planning on going on a trip.
Great idea about using it for remembering the hitch height! Thanks!
I stopped using it to remember the clearance height required for hitching. For some unknown reason, my LevelMate Pro struggles with this feature. I set it where I want it, and then the next time that I use it, it forgets where I set it and it tells me that I’m high enough to clear the hitch ball when I’m actually not.
__________________ Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
Got tired of changing the batteries before and after every trip! Just did the install described here and it tests great! I installed an on/off switch in the light housing in my storage compartment of the 23fb. Tapped power from the 12v to the light.
