Old 07-14-2007, 11:36 AM   #15
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Dave,
Consider even wider than 2 x 8s. 10 or 12s make backing onto them easier, and you are not lugging them around anyway. Pressure treated of course. Welcome to the forums!
Vaughan
Old 08-02-2007, 10:52 AM   #16
2007 25' International CCD
Arlington , Virginia
Originally Posted by vswingfield
Hi Dave,
Vaughan
So if I have a 25' dual axle trailer, then cutting a 10' or 12' piece of 2x10 or 2x12 into say four equal length pieces should be sufficient?
Streamer1 is offline   Reply With Quote
Old 08-04-2007, 09:54 PM   #17
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I cut one 2X8 about 12 1/2" at the base with a slight angle on each end. Many times this board goes between the tires when I need to back up onto boards. My second 2X8 is about 2" longer at the base. I've never needed to raise one side of the trailer any higher than 1 1/2" so these two have served their purpose adequately.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-04-2007, 10:33 PM   #18
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Never had to adjust more then 1 1/2 inches? Lucky guy! I have 2 sets of Lynx Levelers and will build 3 inch ramps alot. I like them because they stow in a case under the bed when not in use.
The worst place for level is a trip we make every year to a lake in Northern AZ. We park in a meadow that slopes down to the lake. This year we dug about an 8 inch deep hole on the high side and added 3 inches on the low side. It was perfect!
Richard
Old 08-04-2007, 10:45 PM   #19
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
Fiber Diet...
i carry 7 pcs of 2x6 about 14 inches long that i stole from a construction jobsite. i might add w/o guilt of any sort.
if you boondock, 1 1/2 - 3 inches is not outa the question for leveling.
kevin
Kevbo10 is offline   Reply With Quote
Old 08-04-2007, 10:49 PM   #20
2002 25' Safari
Dewey , Arizona
Images: 62
kevin
You better check that again Kev. I think those went up in flames at Deadhorse in February.
Richard
Old 08-04-2007, 11:11 PM   #21
Pardon...
i'm loosing all faith...
what happens at a rally; stays at a rally.
don't divide my measurments by 2.
k.
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
