Old 04-08-2016, 07:17 PM   #15
dwhitake's Avatar
1972 23' Safari
1978 31' Sovereign
Akron , Indiana
I know this is an old thread but...
I need help. I purchased a 72 safari that came with 3 stabilizers. All of them were removed and inside the camper when I got it.
One set was mounted to a long metal piece. And the other is just by itself. No long metal channel.
My question
Do I need he long meta channel along with a another jack or can I just buy another jack?
dwhitake is offline   Reply With Quote
Old 04-08-2016, 07:32 PM   #16
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Three external walk arounds before movement is my procedure. Some may feel this is overkill. But it has been sometime since I have had a mishap when pulling away.
MICHAEL
Old 04-08-2016, 08:40 PM   #17
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
My question
That channel is not used on Airstreams as they come from the factory. Though, you can use the channel or you can mount the individual stabilizers to the frame of the trailer. The reason for the channel is for trailers that do not have attachment points like the cross members in the Airstream frame or the cross member is not at the correct location.
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Vintage Tongue Jack - Reese IndyAnne Jacks, Stabilizers, Lifting and Leveling 11 10-19-2011 01:32 PM
Help leveling a permanent install on unleveled ground mattmorphett Jacks, Stabilizers, Lifting and Leveling 5 09-22-2011 04:16 PM
