Old 12-03-2013, 06:15 PM   #1
tarh2o's Avatar
1975 25' Tradewind
Boerne , Texas
Leveling Jack End Bolt Stripped
Well I finally have moved into my 1975 Airstream and it appears that one of my leveling jacks has a stripped driver nut on the end that is used to activate the jack up or down.
I've scoured the archives and have not seen any threads on this specific topic. Are there any replacement parts that I can get to replace just the activator rod with the rounded over driver nut? I haven't seen any at Inland RV or ODM.
Any help would be most appreciated.
TARH2O
1975 25' Airstream TradeWind International - Under Renovation
2012 MB ML350 BlueTec
tarh2o is offline   Reply With Quote
Old 12-03-2013, 06:57 PM   #2
Central , Mississippi
I had the same issue, one item of note: when the nut falls off, the entire arm is free to swing down on its own. Make sure you tie it all up if you are moving the trailer.
Anyway - I pulled out the threaded rod and used a coarse threaded die to re cut threads. If I recall, the original nut was fine threads and a course thread still has some meat to cut. I also cross drilled and inserted a cotter key to keep the new nut from backing off.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-03-2013, 06:58 PM   #3
rogerdodger's Avatar
Fresno/Clovis , California
I have a leveling jack that the frame was bent. I may be able to remove just the shaft bolt, if you dont find another source. I will mail it to you.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 12-03-2013, 07:37 PM   #4
1981 31' Excella II
New Market , Alabama
A new bal jack is pretty cheap. I would just weld the nut back on or weld a new one on.
Perry
Old 12-03-2013, 08:12 PM   #5
tarh2o's Avatar
1975 25' Tradewind
Boerne , Texas
Actually its not the threaded part that is the problem. Its the end bolt that I use to lower it down and retract it. The bolt head has been rounded over and I can't get a bite on it with a socket.
TARH2O
Old 12-03-2013, 08:19 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If you are stuck you can jam something between socket and rounded head. Or, buy a new 6 point socket and epoxy it onto the rounded head.
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-03-2013, 08:48 PM   #7
1977 Argosy 24
Milltown , Wisconsin
Just have a nut the same size as the old one welded on top of the old rounded one. Fixed
ventport is offline   Reply With Quote
Old 12-03-2013, 09:51 PM   #8
This may be the easiest way to get it fixed, but if you need the shaft, let me know.
Roger
Air# 29488
Old 12-04-2013, 04:54 AM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Just an FYI, one of the reasons the stabilizers get bent and broken is trying to use them to level the trailer. They are not leveling jacks.
Old 12-04-2013, 05:22 AM   #10
Taylormade's Avatar
1978 31' Sovereign
Ding Ding Ding. We have a winnah.
They're BAL STABILIZERS, not levelers. Level the trailer with 2x6s, plastic deals, whatever, then when it's level, drop the stabilizers down to hold everything where it is. For those who don't already know, using them as levelers puts a LOT of stress on the frame and will twist or bend it, especially in the older models where rust may be prevalent.
Ut Prosim
Taylormade is offline   Reply With Quote
Old 12-04-2013, 05:26 AM   #11
1984 31' Excella
Norfolk , Virginia
Images: 11
Rounded Stabilizer nut
Sears makes a tool like a socket that grabs the rounded head.
I'd weld a nut to it.
Beginner is offline   Reply With Quote
