Old 04-25-2012, 06:02 PM   #1
1986 27' Airstream 270
somonauk , Illinois
leveling a '84 Excella motorhome
Just purchasedmy1st motorhome and don't have any idea how to level.
Any advise is appreciated.
rolak235 is offline   Reply With Quote
Old 04-25-2012, 06:23 PM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Does it have jacks mounted underneath? If so, you'd use those to level it. I'm not really familiar with the systems, but the general idea is that you have a control inside you can raise and lower each corner with.
If not, you need to raise the "low" tires to get it level. As a former motorhome (without jacks) owner I can tell you that being off level in one direction (side-to-side or front-to-back) isn't too bad, but when it's off in both directions it can get annoying quickly.
For that purpose, I used (and in fact still use with the trailer) the plastic blocks that look like giant Legos. I had 14 and occasionally needed all of them. You build up a little ramp and trial and error to get it level.
Also keep in mind it doesn't have to be perfect. Further, my motorhome, if it was a bit off when I was done with the blocks, would find its way to level after a few hours...but that may have been due to the old shocks.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 04-25-2012, 06:46 PM   #3
Hey there and welcome!
An '84 Motorhome?
Is it a Classic?
If it is... you will get the more specialized help you need in the Classic Motorhome section.
If it is a Motorhome, and it has the Levelers factory mounted, the system is normally a HWH 100 system and will be on the left of the drivers seat on the floor..
Read this...
http://www.hwhcorp.com/ml40256.pdf
Air Bag Leveling '79 Excella 71tr6r Classic Motorhomes 10 05-23-2013 10:18 PM
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 02:32 PM
1979 28' Excella Leveling System marydixon555 Jacks, Stabilizers, Lifting and Leveling 5 04-28-2011 06:19 PM
Leveling a trailer APB On The Road... 29 07-11-2003 10:02 AM
