Old 10-12-2014, 06:28 AM   #1
wscampo's Avatar
Leveling
I need to level my 2010 Flying Cloud 23FB approximately 2 inches side to side. It is positioned so that I am unable to drive it on blocks. Can anyone help me with a good or best practice for using a bottle jack or jack stands? We have a very stable surface.
Thank you.
wscampo is offline   Reply With Quote
Old 10-12-2014, 06:39 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
That's not possible, unless you lifted it into position with a crane. If you can hitch up to pull it, you can get blocks under it. Pull it forward just far enough to position the leveling blocks where you want them, then back it onto the blocks.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-12-2014, 06:45 AM   #3
wscampo's Avatar
It was positioned close to a tree for a desired location and security. I do not currently have access to the equipment used.
Old 10-12-2014, 06:52 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I'm afraid you are out of luck then. Airstreams cannot be leveled using jack stands or any other device other than one which relies on the tires and axles for side to side leveling. I'd leave it as is until you are able to move if forward (or back) in order to position some blocks or boards under the tires.
Bob Martel
WBCCI# 5766
Old 10-12-2014, 06:58 AM   #5
wscampo's Avatar
Thank you
Old 10-12-2014, 07:05 AM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
This could be a TERRIBLE suggestion - and if so, hopefully smarter people than I will chime in an tell you.
One option would be one of those hand dollys that can move the trailer - maybe you can rent one?
Another option (probably very bad - don't do this) would be to take air out of the high side tires.
(Donning my slings and arrows shield now :-) )
SteveSueMac is online now   Reply With Quote
Old 10-12-2014, 07:10 AM   #7
wscampo's Avatar
What about jacking high enough to position leveling blocks under the tires?
Old 10-12-2014, 07:22 AM   #8
r carl's Avatar
Lin , Ne
They jack up the trailers to replace the axle so it can be done.
Old 10-12-2014, 07:31 AM   #9
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
You can do it with a bottle jack
This is easier than you think.
Get a good bottle jack and some scraps of plywood or other flat lumber as wide as your tires.
Chock the trailer wheels securely on the high side of the trailer so it won't roll.
Place the bottle jack on the axle mounting plate (never on the axle tube) on the low side of the trailer. Jack that side up until the wheel(s) is/are off the ground.
Place the scrap lumber (or Legos if you have them) under each low-side tire.
Release the jack until it's no longer in contact with the trailer--put all the weight back on the wheels.
Check to see if the trailer is level.
Repeat as necessary.
Safety above all! Never get under anything that is supported by a jack.
Old 10-12-2014, 07:49 AM   #10
wscampo's Avatar
Thank you. I appreciate your help.
Old 10-12-2014, 07:58 AM   #11
SteveH's Avatar
Common Sense , Texas
I have a set of these and really like them: 3604 - Camper Leveler
They allow you to level the amount you need, not just the amount of the block, and also serve as wheel chocks after the leveling has been done. I've even used my set and a friend's set together to lift the trailer high enough to remove the holding tank cover to replace the valves. However, like most any other blocks, you must use the tow vehicle to either pull or back the trailer onto the blocks.
I have no association with the company other than being a happy customer.
Regards,
Steve
Old 10-12-2014, 08:04 AM   #12
wscampo's Avatar
Thank you.
Old 10-12-2014, 08:20 AM   #13
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Your trailer will have jacking points marked on the belly pan. If there isn't a sticker pointing to it, it is also marked by a two inch or so square or aluminum. Jack from there, piece of cake.
2012 Dodge Durango Hemi/AWD
Old 10-12-2014, 08:30 AM   #14
KYAirstream's Avatar
Northeastern , Kentucky
Pretty sure the only place you want to jack is at the axle mounting plate (big piece of steel the axles mount to). I believe those markings at the front and rear are strictly for stabilizing the trailer.
As far as leveling the trailer in place, anyone ever try using a heavy duty scissor jack under the axle mounting plate to get the necessary lift?
KYAirstream is offline   Reply With Quote
Leveling a trailer APB On The Road... 29 07-11-2003 10:02 AM
hydraulic leveling system kooblekidz Airstream Motorhome Forums 4 02-27-2003 01:52 PM
leveling concerns jwaldin Jacks, Stabilizers, Lifting and Leveling 8 02-24-2003 02:34 PM
Load Leveling Hitch Fine Adjustment Road Ruler Hitches, Couplers & Balls 1 02-23-2003 11:32 AM
