Old 10-12-2014, 08:39 AM   #15
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by SteveH View Post
I have a set of these and really like them: 3604 - Camper Leveler
They allow you to level the amount you need, not just the amount of the block, and also serve as wheel chocks after the leveling has been done. I've even used my set and a friend's set together to lift the trailer high enough to remove the holding tank cover to replace the valves. However, like most any other blocks, you must use the tow vehicle to either pull or back the trailer onto the blocks.
I have no association with the company other than being a happy customer.
Absolute ditto here! WAY better than the Legos I used to use. OP isn't hooked up to tow it unfortunately but I highly recommend those levelers. So simple - so genius!
Old 10-12-2014, 09:07 AM   #16
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Originally Posted by KYAirstream View Post
Pretty sure the only place you want to jack is at the axle mounting plate (big piece of steel the axles mount to). I believe those markings at the front and rear are strictly for stabilizing the trailer.
Not per my manual and experience. It has one per side, to the rear of the axle, big blue letters "JACK" with an arrow point to the plate. That one point will lift both axles on that side. I use a block of wood on top the the jack, so it's not steel on aluminum.
2012 Dodge Durango Hemi/AWD
Old 10-12-2014, 09:11 AM   #17
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Nope those are the points to jack from. I have changed tires on my Airstream a couple of times and use those points to jack from. I've used a floor jack with a piece of wood on the jack itself. Works great and will provide enough lift to get both wheels on the same side off the ground. Those marks on my Classic are behind the axles on both sides of the trailer. None forward of the axle.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-12-2014, 09:25 AM   #18
KYAirstream's Avatar
Northeastern , Kentucky
Leveling
Interesting. I've always jacked by lifting in between the wheels along the axle mounting plate. Works really well and doesn't put any unusual torque on the frame. Always thought those other points were intended for stabilizing.
Just curious--where are those markings in relation to the rear stabilizing jacks?
KYAirstream is offline   Reply With Quote
Old 10-12-2014, 09:39 AM   #19
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Axles are holding it up!
If you call Airstream customer service, they will tell you that you can lift the trailer using the marked lifting points.
Ky and Jack are also giving you good tips. You can lift using the axle mounting plates. They are obviously strong enough to hold the trailer up!
Here's a photo of a 28' elevated on timbers to get the freshwater tank out. The trailer was lifted with a jack on axle mounting plates. I did back it up on the first couple of boards but then used the jack to lift it enough to the other timber in place.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 10-12-2014, 09:52 AM   #20
Wayne&Sam's Avatar
Images: 21
It probably varies on models, but on mine one is about 2" and on the other side it's a foot or less, due to the need to avoid waste pipes.
Old 10-12-2014, 09:53 AM   #21
Wayne&Sam's Avatar
Images: 21
Name:	ImageUploadedByAirstream Forums1413129231.077632.jpg
Old 10-12-2014, 12:28 PM   #22
richw46's Avatar
Lexington , Kentucky
Originally Posted by Wayne&Sam View Post
Attachment 224192
So is that diamond the actual location where you put the top of the bottle jack? Sorry to be obtuse, just want to be sure.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-12-2014, 01:16 PM   #23
Wayne&Sam's Avatar
Images: 21
Yup. But I also use a piece of wood.
Old 10-12-2014, 01:18 PM   #24
SteveH's Avatar
Common Sense , Texas
Just my opinion, but I'd use a floor jack. A bottle jack would slip too easily.
Regards,
Steve
Old 10-12-2014, 01:59 PM   #25
richw46's Avatar
Thanks, Steve. I was thinking more of a tire change, using my TV jack. I agree on the floor jack if available. I'm new at this and haven't had to change a tire yet. I don't want to poke a hole in the bottom if I do.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 10-12-2014, 02:04 PM   #26
SteveH's Avatar
For a tire change, it's MUCH easier to drive the trailer up on a block on one tire like I linked above. It will lift the other tire off the ground, and no jack needed.
Regards,
Steve
Old 10-12-2014, 02:10 PM   #27
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Using the Anderson levelers can you do it solo easily? Put the parking brake on the TV so you can walk back to check and choke?
Can you drive forward off the leveler safely without it damaging tires?
Kelvin
Old 10-12-2014, 02:40 PM   #28
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I use a bottle jack AND I have several pieces of plywood that I use at the stabilizer jacks. I use a piece under the jack if the ground is soft and one on top of the jack to spread the load. That jacking point is on the frame rail and if it slips you've penetrated the belly pan. The axle mounting plate is also a good spot so whichever you want to use.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Leveling a trailer APB On The Road... 29 07-11-2003 10:02 AM
hydraulic leveling system kooblekidz Airstream Motorhome Forums 4 02-27-2003 01:52 PM
leveling concerns jwaldin Jacks, Stabilizers, Lifting and Leveling 8 02-24-2003 02:34 PM
Load Leveling Hitch Fine Adjustment Road Ruler Hitches, Couplers & Balls 1 02-23-2003 11:32 AM
