Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 07-04-2009, 11:13 PM   #1
Profile:  Spring , Texas
Land Yacht Air Leveling Mod
We have a1993 Land Yacht MH. It has air suspension that comes on when the ignition is turned on and off with it off. It only controls the rear of the coach the front is fixed pressure air bags. Does any one know if it is possible to add a switch and wire it in to activate the leveling system with the ignition off when we are going to be stationary for a while. We have levelers but they are troublesom and most of the places we are on a concrete slab that is level and we just turn the ignition on every now and then to keep it level. We got use to the coach mooving arround a little when we move arround.
Appreciate any ideas or info. Pat - Spring TX
porourke is offline   Reply With Quote
Old 07-05-2009, 11:21 AM   #2
blacksheep's Avatar
Profile:  1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
So, you are saying it leaks down slowly? If so then it would be best to find the leak and repair it. Make sure the bags are aired up and then use soapy water in a squirt bottle on every air line connection. The bubbles tell the story.
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles,a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 253,000 miles!
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
'79 28' Airstream Air Stream Ambassador Land Yacht eBay Watch Airstreams on eBay 0 06-10-2009 09:20 AM
Equalizer and Air Leveling System OB Bambi Towing, Tow Vehicles & Hitches 1 05-23-2009 11:59 PM
Land Yacht Air Bag Problem HELP!! tictoryde Airstream Motorhome Forums 18 05-23-2006 10:18 AM
Failed Air Suspension on 94 33 ft Land Yacht rayschell General Motorhome Topics 0 11-21-2005 09:40 PM
Puzzling Onan Air Filter on 1995 Land Yacht scotta Airstream Motorhome Forums 1 08-20-2003 07:37 AM
