Old 06-01-2010, 08:36 PM   #1
1979 25' Tradewind
Beaufort , North Carolina
jacking up one side of trailer
OK, I heard about running one wheel up etc... but I need to have " both" wheels up on the same side. I have a 79' Tradewind that "was fine when I parked it" about 3 yrs. ago.
With two flat tires on one side, as soon as I started jacking up that side the other side tires lost air. Now if I am given a jack point aft of the rear wheel which is a very small area where do I put a jack stand when the floor jack is taking all the room? I would love to have the unit on four jack stands while I work on the brakes and bearings but on each side I need a jack point and a spot to add a stand. I don't notice a jack point in front of the forward wheels. Is there one? I have four flat tires, limited room between the deck and the bottom of the trailer. I have to admit that I jammed 2x4's under the vertical supports to keep from having a total belly flop.
I'm replacing all the plumbing with "Seatech" plumbing which I use on yachts and intalling a new updated 20 amp inverter, interior LED's etc...
Hope to have it ready in 9 days.
anson is offline   Reply With Quote
Old 06-01-2010, 09:15 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Welcome to the forum.
Hi, your tongue jack holds the front of your trailer up. If you use a bottle jack on your axle brackets, you will have room to put jack stands on the same axle brackets. For safety, I put one jack stand under each axle bracket and one on each frame end, just in front of the rear bumper.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-01-2010, 10:37 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
As ROBERTSUNRUS suggested, the axle bracket (the vertical piece of steel to which the axles are bolted) is the place to jack... on a double axle trailer, you can use a low profile car jack between the two axles to get the first side up on jack stands, which should be situated w/ one behind the rear axle and one in front of the front axle.
Be careful when lifting using a car jack as they tend to push things sideways... I use a bottle jack normally.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 06-02-2010, 05:44 AM   #4
1979 25' Tradewind
jacking up
Thanks for the advise. I just wanted to be sure I don't rack the frame or crack it.
Old 06-02-2010, 08:27 AM   #5
Maniacal Engineer
barts's Avatar
Yup... never hurts to make sure. Since the axles support that plate normally, lifting via the axle plate is safe. The plate can be supported w/o difficulties w/ a single jackstand anywhere along its length. I've had my trailer on two jack stands and the front jack for several weeks when changing axles; whenever possible I left a pair of tires on one axle or the other just in case of problems...
- Bart
Bart Smaalders
Menlo Park, CA
jack points, jack stands, jacking one side, jacking trailer
jacking trailer NY_Chairs Axles 3 06-25-2009 06:53 AM
Trailer jacking question frozen chosen Jacks, Stabilizers, Lifting and Leveling 6 03-28-2007 09:48 AM
Trailer heavy on one side! Chopper Axles 33 09-27-2006 09:21 AM
Urgent...Jacking trailer hhuber Jacks, Stabilizers, Lifting and Leveling 20 10-06-2003 10:47 PM
