Old 09-24-2005, 07:39 PM   #1
Tinsel Loaf's Avatar
Jacking up an Airstream
Here is how I relieve the load from the axles when parked for extended periods of time or if the campsite is not level. Pictured is the equipment needed to make the job easy. The wood rounds are used to spread the load of the screw jack on terra firma or asphalt. Without the wood base the screw jack will sink into soft ground or mar asphalt on a hot day. There is not enough room between the tires to use the screw jack lever unless you are under the Airstream so use a hydraulic jack. Raise Airstream using the hydraulic jack on a level surface ( not like the picture it’s only a visual clue ) until both tires just come off the ground and adjust the screw jack centered snugly against the frame. Within seconds the axle rubber relaxes and the tires are firmly on the ground. Remove the hydraulic jack and repeat on the other side. Put down your stabilizers and your done. Each side takes only minutes to do. Remember to retract your stabilizer jacks any time you adjust the front electric jack. Failure to retract the stabilizers may damage them even if the front jack is adjusted a small amount. Don’t forget to remove the jacks before you pull out.These screw jacks are very stable and will stay where set and not unscrew on their own with the weight of the Airstream on them. This method works for me, your results may vary.
Name:	Equipment needed.jpg
ID:	14779   Click image for larger version
Name:	All Jacked Up.jpg
Tinsel Loaf is offline   Reply With Quote
Old 09-24-2005, 08:22 PM   #2
_
hi tinsel loaf
nice pictures.......so colorful and clear.
i'm not exactly sure if/why one should do this......relieving the load? once the jack is removed the weight is back on the wheels/tires and therefore the axles right? so what does this accomplish? i suppose if the trailer was parked for a very long time this might exercise the rubber but imagine it would have to be do mulitples....like real exercise.....like just driving it round the block a few times. and the trailer does settle back down to the same position/height when the jacks are removed....right? i'm not seeing how this helps with an uneven camping site, unless lifts are slid under the tires while off the ground?
also, it looks like the jack is on the frame, but the manual does suggest that there are specific "jack points" which are the only spots we should use for jacking (like to change a tire/wheel). these points are marked and near the ends on most of the trailers....i assumed the frame has been beefed up under the markers....to support lifting.
so i just wonder if you've checked with inland andy or some other air guru on this proceedure?
cheers
2air'
Old 09-24-2005, 08:41 PM   #3
I tried the manufacturer suggested jack points towards the rear but could not close the door when raised at those points. I remove the weight so the axel rubber does not get a memory sitting for a long time and gets most of the weight off the tires and bearings. Does it help? Maybe, maybe not, but it can't hurt. I found it is a good jacking point to do wheel service and adjust the brakes.
Old 09-25-2005, 03:48 AM   #4
Originally Posted by 2airishuman
once the jack is removed the weight is back on the wheels/tires and therefore the axles right? so what does this accomplish? 2air'
2air, the distinction is, I believe, between the screw jack, which stays in place under the frame, and the hydraulic jack, which lifts the trailer so that the screw jack can be placed to eventually take the weight. Most of the weight is left on the screw jack, with just a little on the tires to stabilize the trailer. This is also what I do. The trailer is then left with a screw jack under each side frame. Also, this is the guru approved strong point for jacking the trailer, rather than the factory labelled parts. It is an enormous girder, clearly visible. I hope this helps.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 09-25-2005, 03:51 AM   #5
and here is a link to Andy's explanation:
http://www.airforums.com/forum...ng+point+frame
Old 09-25-2005, 05:15 AM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
so where did you get the screw jacks from?
john
you call them ferrets, i call them weasels.
Old 09-25-2005, 06:26 AM   #7
For what it is worth, when I toured the Jackson Center Airstream factory, the tour guide emphatically stated that in all the years he had worked at AS only one Airstream had experienced an axel going bad. Certainly among the many units sold during his 40 years, some must have set for extended times and perhaps some were in constant use but whatever their use the system did not deteriorate.
RTaylor
rtaylor537 is offline   Reply With Quote
Old 09-25-2005, 06:34 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
RTaylor
I would take a major exception to that statement...I have seen many, many failed axles, now by failed if he means it didn't break and fall off the trailer...okay...but my definition of failed is when it no longer meets the orginal specfications...and I know there are many, many of those axles out there...I have an 80 model sitting in my yard that the axles are shot, the trailer is gutted and the torsion arms are pointing upwards....and the top of the wheel arches are about level with the rims...
Aaron
WBCCI #XXXX AIR #2495
Old 09-25-2005, 07:46 AM   #9
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
I consider my old axles as failed and they sat loaded for 13 years. Prior to that the trailer was used as housing so it sat a lot then.
Andy did tell me that it was a good idea to relieve the load when storing - it will help get extra life out of them.
I am already planning on jacking my new axles for winter storage this year.
My Old Axles prior to replacing.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 09-25-2005, 08:02 AM   #10
StingrayL82's Avatar
San Angelo , Texas
Images: 37
We got very lucky with our Sovereign...it was at an RV Resort, on jack stands for 25+ years, so the axles still have plenty of life in them. You can see pictures of it, when it was still at the RV resort, on the member's pictures page.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 09-25-2005, 08:17 AM   #11
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
The place that Airstream identified for jacking up my 30' trailer are so far to the rear of the trailer that they are impossible to use. So, when I was at the factory for service this past July, I asked where a good point was to place the jack. The service guy told me to place the jack anywhere on the the frame, as it appears that Tinsel Loaf has done, except that he also mentioned (the same as Inland's Andy did in the link you provided) that you have to be careful to place the jack far enough in so as to not bend the C-channel on the outer edge of the frame.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 09-25-2005, 09:49 AM   #12
john
John, I got mine from Wal-Mart. They have a set of four hardened alloy stands for very little money. They are usually in the RV section, near the toilet chemicals in most stores I've been in. They are adjustable in steps, rather than with a screw, but they fit just right under the frame, with a wood pad top and bottom to spread the load. I use one each end of the axle frame on each side, total four. I use the gap between the wheels for the hydraulic jack. The trailer is then supported on 4 stands, one front hydraulic jack, 4 corner stabilizers, just touching, and 4 tires, just touching. Can't be too sure!
Nick.
Old 09-25-2005, 11:17 AM   #13
I bought the jacks from McMaster Carr, Inc. Los Angeles, California.
Just a note: I noticed the photo’s makes the frame look like it is slightly bent where the jack is placed. This is not the case. I put a straight edge on it and it is not stressed, The frame is perfectly straight. The shape of the belly pan and the dark paint from the jack head gives it that impression through the lens of the camera. I hoped the pictures helped.
Remember your results may vary.
Old 09-25-2005, 01:47 PM   #14
_
sometimes slow on the up take......
thanks nick,
that makes more sense to me and now, rereading the first post i see this distinction.
so far the 34 hasn't nested in one spot for more than 2 weeks, with 10k miles towing since new in april.....now this winter i might "settle" in one southern locale.....guess i'll look into this.
also i'd like to lift the side for tire rotation....and jacking near the middle seemed logical, while contrary to the book.
regards
2air'
2air, the distinction is, I believe, between the screw jack, which stays in place under the frame, and the hydraulic jack, which lifts the trailer so that the screw jack can be placed to eventually take the weight. Most of the weight is left on the screw jack, with just a little on the tires to stabilize the trailer. .
Old 09-25-2005, 02:06 PM   #15
All Airstream trailers since 1961 should be lifted off the ground at the axle mounting plate, "only".
The "jack" labels on the underbelly are for "stabilizing only". If you attempt the jack the trailer off the ground at the "jack" labels, the door will probable jam so that it will not open or close, amoung other things such as damage to some sheet metal components.
If you wish to remove weight from the axles for long term storage purposes, jack the trailer up at the axle mounting plates, and place a "stabilizing jack" at the underbelly points so indicated. Do not support the trailer from the jack label points only, if you want the tires off the ground. Several different damages will occur, depending on model, if you do.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-29-2005, 12:56 PM   #16
1986 34' Limited
Prospect , Tennessee
Enormous girder
Do anyone know if this "enormous girder" concept holds true for the older larger trailers? I just bought an 86 Airstream 34 foot Limited and noticed that part around the wheels looked pretty sturdy, but was afraid to jack up under anything except the "approved spot" way behind the wheels. I also noticed on the forum that lots of people don't even want to jack up in the "approved spot" In getting the tires replaced I just drove two of the three tires up on blocks I made, and the 3rd was off the ground. It worked OK, but I had to keep moving the blocks and getting back on them doing one side and then the other as the tire guy went from tire to tire. It sure would be easier to just jack up between the tires, but I have read enough notes from doubters to worry about doing that. In fact, the reason I made the block arrangement was to not have to jack it up at all, because lots of people seem to think jacking it up anywhere is a bad idea. However, even with 2 , 2x8s screwed together and tapered on the ends (3 inch actual lift), it was hard to get the tires off and new ones on without letting air out (We were off by about 1/4- 1/2 inch, so I guess I'll have to add another level on my block arrangement. So, to jack or not to jack, and where to jack if you do, is the question. There doesn't seem to be any clear consensus that I can see.
Nick.
Lee
Full Time.....keeping the shiny side up
Lee Davis is offline   Reply With Quote
Old 09-29-2005, 12:59 PM   #17
1986 34' Limited
Oops
I goofed and didn't read the note right before mine posted by Andy of Inland RV, and I understand he is the guru of this stuff, so it sounds like the place to jack is between the wheels if you have to do it. Sorry...too much to read...too little time. Thanks for everyone's patience
Lee
Lee
Old 09-29-2005, 01:20 PM   #18
Lee Davis
Regardless of the length or year Airstream trailer, from 1961 to present, the preferred jacking (lifting off the ground) place is the "axle mounting plate".
No harm of any kind can occur, when you use the axle mounting plate. As an example if someone wanted to change the axles on any length Airstream trailer, simply jack it up using the axle mounting plates. Additionally, of course, it's always a good idea to add jack stands when the complete trailer is lifted off the ground.
However, if someone does not wish to jack up the trailer, you can pull a wheel up on blocks as you have done. Obviously that only works for a tandem or tri-axle Airstream trailer.
Once again, the "jack" label underneath the trailer, is for "stabilizing jacks only". Never raise the trailer from those points. To do so is almost a guarantee of some structural damage.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-30-2005, 07:24 PM   #19
Loco Airstreamer
shannon's Avatar
1970 23' Safari
Denton , Texas
Off to Bad Start?
Went to remove old tires / rims from '73 - 23 Safari I am buying from a friend, and removed each side's tires but once weight was on stands, maybe not on axle mount plates but very close to them - stands began to sink since we finally had some rain around here. SO, I quickly slid my floor jack to center of axle to prevent total disaster. Now, it looks to my eye as if axle may have upwards arc in it. Put weight back on stands and moved jack off center and distributed some weight on the jack.
Is this a disaster? Will it straighten itself out after weight is redistributed to wheels?
I assume this trailer has been sitting on its axle the entire time. How can you tell if your axle is worn out, sprung out or whatever the term is?
I find it hard to believe they would manufacture a critical part like an axle with steel square tubing wall so thin it would arc.I'm a welder, so if it is bent, and does need to be straightened, I am tempted to sleeve it with a new piece of square tubing to make it BULLET PROOF.
Somebody let me know ... tires ready tomorrow ... bring it to its new home on Sunday! Thanks in advance for helping a newbie,
shannon
shannon is offline   Reply With Quote
Old 09-30-2005, 07:37 PM   #20
_
oh my goodness you really messed up!!!
not really
hi shannon and welcome to the forums. someone will likely beat me to it, but not to worry the axles are "arched" up at the factory...part of the wheel alignment process....i think it's how they create camber?
so you well lucky this time......not wait for your next real screw up to post again.
cheers
2air'
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 10:20 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
