couple of ideas
hi tim- I just used the tongue jack to tilt my coach one way or the other, to allow for a little easier crawling around under it. I think it would also be simple to hook up to your tow vehicle (I don't have one) and drive the coach up onto some planks, to gain some height. Be sure to block the tires securely. As far as the more involved jacking up goes, I did this to drop my axles and paint the frame in that area, and I put the jack under the big frame member right by the axle, then also adding more props after it was high enough. There are other threads on this subject, I am not an authority on it but it worked for me. I would suggest simplest, and safest, over all other ways. Good luck- tim
