Old 04-21-2010, 08:01 AM   #1
Jacking up
Where do I place the jack to lift my 25 ft. Excella? What kind of jack do I use?
lightng is offline   Reply With Quote
Old 04-21-2010, 08:09 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
For what reason are you lifting the trailer - and what model & year trailer?
Old 04-21-2010, 08:27 AM   #3
Sort of depends what you want to do when the trailer is lifted.
Old 04-21-2010, 10:21 AM   #4
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
My '99 Safari has a spot on the bottom indicating where the jack should be placed, it is towards the back, behind the wheels. I don't know if your unit has this decal or not. You need to be very careful about how you jack up a trailer, Airstream or SOB.
Bear in mind that you never want place the jack on the axles.
If you only want to pull a wheel, a lot of times it's easier just to pull one of the wheels up on to a (STABLE) board/s and that in turn will lift the other wheel up off of the ground. Some folks build "ramps" for this purpose, you can also purchase ready made versions of the same (one of which, the Trailer Aid I carry in my AS.
traileraid.com
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 04-21-2010, 11:07 AM   #5
1971 29' Ambassador
Leonardtown , Maryland
When necessary to put both wheels in the air, I use a bottle nose jack and place it so to push up on the frame behind the wheels. Do not put the jack on any part of the axle to lift, much damage can occur.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 04-21-2010, 11:12 AM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
If your trailer has dual axles and if you just want to pull wheels off, then I find it far easier to just run the adjacent wheel up on a ramp made of those interlocking plastic blocks - the other wheel will be left hanging in the air - much simpler, quicker, and safer than using bottle jacks IMHO.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 04-21-2010, 02:26 PM   #7
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
It takes two 2x8 or 2x10 boards to lift one wheel off the ground when I put the other wheel on the boards. I bevel cut the board ends to make it easier on the tires. Even then, one wheel may still touch the ground because of uneven ground or fate. Then moving the tongue jack up or down will lift the wheel enough.
There are plates on the bottom of my trailer indicating places where it is safe to jack the trailer though I haven't used them. One was missing and I had it put on at JC.
There are threads about jacking with much, sometimes contradictory info, on what to do. Try a search if you want to learn more.
Gene
Old 04-25-2010, 07:21 AM   #8
I have a 2001 25ft. excella. The tires have sunk into the sand quite a bit. I wanted to jack it up and put solid cement blocks under it.
Old 04-25-2010, 07:36 AM   #9
Master of Universe
Gene's Avatar
Wouldn't is be easier to try to tow it out of the holes and then stabilize the ground. A jack may sink in too.
Gene
Jacking up an Airstream Tinsel Loaf Jacks, Stabilizers, Lifting and Leveling 86 02-22-2017 08:53 PM
Jacking up a new Airstream.. SafariSS Axles 13 02-09-2007 06:03 PM
Jacking the Caravel Melody Ranch 1969-1971 Caravel 6 05-23-2006 05:50 AM
jacking up '72 Overlander TimM Jacks, Stabilizers, Lifting and Leveling 4 01-29-2006 04:25 PM
