Old 03-18-2007, 10:02 PM   #1
jump's Avatar
2013 30' International
lubbock , Texas
where are the jack points ... '82 31' excella
and what if you dont have any indicators on the trailer where to jack. i need to remove all four wheels to have the tires replaced and i dont think i trust the local tire shops to know where to place the jack. Sams wants to set it on the rack in the bay area to replace tires and i have a feeling that the guy doesnt know a lot about airstreams.
so...my '82 31' excella does not have any indicators for jack points...how do i figure out where to place the jack and jack stands?
jump is offline   Reply With Quote
Old 03-18-2007, 10:11 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would not jack it, why take the risk? Ramp it, replace two tires, then ramp it again and replace the other two. Two trips to the tire store sounds alot safer then putting a few tons on jack stands...
Richard
Old 03-18-2007, 11:06 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
AMEN!! And leave the trailer attached to the TV. Use another vehicle to transport the wheels.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-22-2007, 11:08 PM   #4
jump's Avatar
lubbock , Texas
what if i have two flats on the same side and really needed to jack...where do i place the jack? huh??
Old 03-22-2007, 11:34 PM   #5
jump's Avatar
lubbock , Texas
previous thread by tinsel loaf : jacking up an airstream...i should pay more attention. maybe i'll catch on to how these things operate after i have embarassed myself more...
never mind
Old 03-23-2007, 10:55 AM   #6
You can place a floor jack, or a bottle jack, between the two tires, and lift the trailer using the "axle mounting plate."
If you wish to add a "jack stand," place it on the axle mounting plate, rearward of the rear tire.
Old 03-28-2007, 09:51 AM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Cursing may be a good 1st step. A last step may be buying a lotto ticket. Cause the odds of getting two flats on one side are high. So you feel a little lucky!!?? Or may be not.
>>>>>>>>>>>>>>>>Action
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
Jacking points on '77 27' International johnmw Jacks, Stabilizers, Lifting and Leveling 13 12-13-2002 12:05 AM
Where are the jack points? barbwire All Argosy Trailers 6 11-11-2002 09:52 AM
