Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 08-11-2008, 09:05 PM   #1
Chip Arnold
Profile:  1976 31' Sovereign
Blairsville , Georgia
jacking location
I have a '76, 31' AS. The repair manual says to jack at the marked locations behind the axle. I can't find and marked location. Anyone know where to put the jack to lift this thing? I want to check brakes.
thanks for any help.
Chip Arnold is offline   Reply With Quote
Old 08-11-2008, 09:15 PM   #2
TBRich
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
There's a whole subforum on this topic...even though they say the jack points are marked, many times they are not...this should give you more than enough information to do it properly and safely... http://www.airforums.com/forums/f457/ Good luck!
TB & Greg...Cockers Annie & Sadie...and Homer the Desert Tortoise
WBCCI Four Corners Unit #3954
AirForums #21900
Please Visit Our...
Décor Site: AZBambi Décors
Old 08-11-2008, 09:39 PM   #3
Chip Arnold
Thanks, lots of info there.
Old 08-11-2008, 09:46 PM   #4
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I only jack up the trailer where the axle is mounted to the frame. This plate has plenty of support. Do not place the jack on the axle tube.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-01-2008, 11:00 PM   #5
mustang
mustang's Avatar
Profile:  1971 31' Sovereign
Kent , Ohio
I pull mine up on wood dont tweek the frame
mustang is offline   Reply With Quote
Jacking up an Airstream Tinsel Loaf Jacks, Stabilizers, Lifting and Leveling 66 12-02-2008 11:49 AM
Yet another jacking question w/oapaddle Jacks, Stabilizers, Lifting and Leveling 6 05-10-2007 07:17 AM
jacking points emanon25 Jacks, Stabilizers, Lifting and Leveling 6 04-25-2006 04:10 PM
jacking up 72 Overlander TimM Jacks, Stabilizers, Lifting and Leveling 4 01-29-2006 05:25 PM
