Old 05-21-2019, 04:51 AM   #15
2007 23' Safari SE
Woodstock , Connecticut
Originally Posted by OTRA15 View Post
Amazing how many simple questions could be answered by starting with the owner's manual . . .
RTFM!
Did read the owners manual. Not very precise. The placard that say's jack with the arrow points to a spot with a rivet but no 2 X 2 plate. I think either Bob's advice or one about in between the wheels will be the way to go.
Curtis
airforus is offline   Reply With Quote
Old 05-21-2019, 07:25 AM   #16
Mollysdad's Avatar
***** OT to the OP's questions *****
I think this is your owner's manual:
https://cdn.airstream.com/wp-content...manual-149.pdf
On p. 8-18 [PDF p. 86/116] is the 12-volt wiring diagram, and on the right edge in the middle is the distribution scheme from the power center/converter. [See Note #4]
but does this schematic cover it?
Peter
Maybe I'm blind. Yes, Page 8-18. Yes, that's the manual. the one I downloaded. I even rotated it so the text is right side up. Yes, Note 4.
Then it says "To 12v. Trailer schematic. See trailer schematic for model"-----but there isn't one.
The next page starts the 120v. schematics, and never returns to 12v.
Did I go crazy?
Old 05-21-2019, 12:29 PM   #17
Long Island , New York
Originally Posted by Mollysdad View Post
Did I go crazy?
Nope!
Sorry, I missed the missing 12-volt schematics.
OTRA15 is online now   Reply With Quote
Old 05-21-2019, 12:42 PM   #18
Mollysdad's Avatar
Nope!
No biggie.
To put a finer point on it, I posted that because people were beating up the OP for "Not reading the manual".
Now being male, I'm adverse to reading instructions, but eventually I try, and sometimes don't find my answer.
Then I ask!
Old 05-26-2019, 09:16 AM   #19
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Originally Posted by Al and Missy View Post
I have jacked my trailers from the jack point label (that is where the manual says to do it) and from the axle mounting plate. It is interesting to me that we are not supposed to use the stabilizers as levelers but it is OK to raise the wheels off the ground with a jack from essentially the same place. When I use the jack points, it distorts the frame so that the entry door will not open if closed or close if open. It seems to me that if the axle mounting plate can support the weight of the trailer when the wheels are on the ground one should be able to jack there. In a similar thread someone suggested to use a load spreader so as not to concentrate the load at a small jack piston top. That sounded like good advice. I use a piece of 2x4 or 4x4 or steel angle if I have one.
Al
I have a couple of hockey pucks that I use on our cars and trailer to spread the load. About $1 each.
SilverCottage is offline   Reply With Quote
New brake shoes and jacking point wayner1239 Brakes & Brake Controllers 6 04-23-2008 07:03 AM
jacking up 1960 travler 60traveler Jacks, Stabilizers, Lifting and Leveling 3 06-19-2003 05:18 PM
Jacking points on '77 27' International johnmw Jacks, Stabilizers, Lifting and Leveling 13 12-13-2002 12:05 AM
