Old 06-03-2010, 09:07 AM   #1
1968 20' Globetrotter
Mansfield , Massachusetts
Jack stands for 28' Argosy
Can anyone out there more knowledgable than I recommend a make and model of Jack Stand for a 1976 28' Argosy. I only use it a few times a year and want to keep the weight off the tires when it's sitting for long periods of time. If you can also advise how many to buy and where to place them I would be very appreciative.
LiisaNiemi is offline   Reply With Quote
Old 06-03-2010, 09:37 AM   #2
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
Regardless if you actually use the trailer, it's a good idea to hitch it up and pull it every once in a while. Not that it makes much of a difference to the trailer, but it reminds you how well they tow and motivates you to go camping more often!
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 06-04-2010, 11:24 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
And gives the torsion axle a lil work out so as not to solidify the rubber.
>>>>>>>>>>>>Action
Old 06-05-2010, 12:16 AM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I would buy four jack stands. I would put one on each axle mounting bracket, in between the wheels. I would put the other two under the rear frame, just in front of the bumper. The two on the axle mounting brackets and the tongue jack will hold it in place the two under the frame rails by the rear bumper are just for added safety. When working on my brakes, I had the jack stands under the rear frame rail, with about a 1/4" gap. No pressure on the frame unless needed.
Name:	IMG_1992 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Single mattress/jack stands/ 97 25' Safari mkrushr Forum Admin, News and Member Account Info 0 07-19-2009 09:21 AM
jack stands out4trout 1968 Overlander 6 12-15-2007 09:06 AM
vintage jack stands pcasa Jacks, Stabilizers, Lifting and Leveling 10 08-09-2007 07:18 AM
Use of jack stands results in crushed propane line ghatfield Hitches, Couplers & Balls 9 06-25-2007 07:02 AM
using 6 jack stands. rama777 Jacks, Stabilizers, Lifting and Leveling 7 11-30-2006 04:20 PM
