04-02-2018, 02:34 PM
2017 27' Flying Cloud
Chillicothe
, Ohio
Jack Stand Not Working
Reconnected new batteries etc. jack stand not working. No power to use lift or light. Checked fuse and it appears ok. What am I missing?
04-02-2018, 02:36 PM
2016 28' International
Sioux Falls
, SD
Recheck battery connections and polarity.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
04-02-2018, 02:39 PM
Tampa
I assume the jack worked fine before you removed the batteries?
The 12v. power to the jack is a single lead with a yellow crimp connector and goes to the + terminal of a battery.
The negative path is through the A-Frame of the trailer. Make sure the three jack bolts are not rusty. Are you sure the fuse is good? Meter it or just replace it.
The ground path meets a common ground strap somewhere inside the trailer. Has anything changed?
Everything else work?
Beyond that, I'd be getting the volt meter out and seeing where I lost power, maybe the switch?
04-02-2018, 02:56 PM
2002 25' Safari
Dewey
Many bad fuses "appear OK", check it with an ohm meter or try another fuse.
Richard
04-02-2018, 03:05 PM
Chillicothe
, Ohio
Thanks for the assist going to get the meter out. Rechecking everything.
04-02-2018, 03:08 PM
2020 27' Flying Cloud
Allen
This was mentioned but do you have the black wire with the yellow crimp on the positive battery terminal?
2020 FC27Hatch
2022 Chevrolet 2500HD
WBCCI#8934
04-02-2018, 03:43 PM
Chillicothe
, Ohio
And I was double checking after reading previous note on same ... yep I didn’t have it on positive. It was on the negative side. End user failure.
04-02-2018, 03:50 PM
Sioux Falls
, SD
Sweet! Glad you found it.
04-03-2018, 11:04 AM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
Just a comment.....before replacing my batteries, I take a picture on the iPhone, to remind me of the correct connections.
04-03-2018, 06:23 PM
Chillicothe
, Ohio
Bahhhhaaaa. I did -
04-03-2018, 06:30 PM
Sioux Falls
, SD
Bahhhhaaaa. I did -
Lesson learned is a good thing because it most likely will never happen again.
04-03-2018, 07:35 PM
2017 19' International
Tallahassee
Same here!
It is a mess of wires ...
04-03-2018, 09:17 PM
Walnut Creek
Bahhhhaaaa. I did -
Obviously you got bit by the somewhat unknow AS cell phone virus that mixes up picture pixels. Very problematic with black and yellow colors. Best counter virus fix is to stand in front of the trailer, when it's raining and wave the cell phone high in the air while you do the AS rain dance. Do not perform this fix if there is any lightening in the area or forecast. Oh, and the virus correction team would be happy to review pictures of your dance. Please post. Pat
04-04-2018, 04:45 AM
Chillicothe
, Ohio
Haha. I’ll keep that in mind
04-04-2018, 01:02 PM
Walnut Creek
Travel safe. Someday we'd like to see your shiny and those smiles. Pat
04-04-2018, 01:31 PM
2017 20' Flying Cloud
Oriental
, North Carolina
One more thought.... I did not like seeing the black (jack stand) wire going to the positive battery terminal, so I put 2" of red heat shrink tubing on the end by the ring terminal. Now it looks like I have a red wire going to the positive terminal.
04-04-2018, 01:48 PM
2019 30' Classic
Canfield
, Ohio
Remove the four screws holding the grey jack cover on and you will see a connection at the top that probably has come off. My new AS had the same problem. Just screw the wire back on.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
04-04-2018, 07:14 PM
Chillicothe
, Ohio
Ironic or great minds think alike.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Cast aluminum tongue jack stand
alvinator |
Jacks, Stabilizers, Lifting and Leveling |
75 |
11-10-2021 08:57 PM |
Electic Jack not working - fuse good - manual not working
ryandanz |
20 |
04-24-2016 10:04 AM |
Jack Stand Use/Placement (long-term parking)
binkers |
Winterizing, Storage, Carports & Covers |
12 |
12-21-2008 07:53 AM |
New Jack Stand for '66 Caravel
pcasa |
4 |
02-05-2008 06:02 PM |
Jack Stand
jfowler218 |
4 |
01-16-2006 01:33 PM |
