Old 06-16-2004, 10:44 AM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
Jack removal
I will want to replace the original tongue jack on my 59 Overlander with an electric. However the original seems to be attached with some kind of heavy rivet. Anyone know how to remove these before I get out the drill.
Over59 is offline   Reply With Quote
Old 06-16-2004, 07:10 PM   #2
Over59's Avatar
Images: 37
Come on guys someone must have taken one of these off.
Old 06-16-2004, 07:14 PM   #3
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
The jack as far as I know is bolted on. I've never seen one rivited. The hole that is left after removal will need to be reamed out to fit the larger diameter elec jack.
Do you have a picture of your jack?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 06-22-2004, 07:04 PM   #4
Over59's Avatar
Images: 37
These look like rivets.
Old 06-23-2004, 03:53 AM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Those rivets may be the first line of defense.
At first glance, the jack on my '67 is simply bolted in place with three bolts on the top of the coupler. I tried to remove the jack this past weekend in preparation of painting the tongue.
Removing the three bolts, I found the jack appeared to be welded to the lower plate (where the chains are)
Ended up leaving the jack in place.
Tom
Old 06-23-2004, 04:14 AM   #6
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
I have to agree`
That does appear to be riveted on.
As with Ken J, the tongue on my unit is bolted on.
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 06-23-2004, 10:02 AM   #7
troubleskeep's Avatar
Richmond , Virginia
ciao
53FC
Any chance of using a grinder? That's what I did, mine were bolts but so rusted that the wrench wasn't working. Took me about 15 minutes. Now went it went back on, I was asked if I wanted it welded on, however, I don't think that would be a good choice. You never know when you may need to remove the jack. Also, on the bottom of the tongue, there is a plate where the jack is stabilized. This could also be welded, though mine was not. Actually, this is where my jack and the plate had rusted through causing the jack failure.
troubleskeep is offline   Reply With Quote
Old 06-23-2004, 10:23 AM   #8
Ken J's Avatar
Durango , Colorado
Images: 14
I can't tell from your pictures how its riveted on - is there a bigger flange with bolts?
FWIW, I would have the whole coupler taken off and weld on a brand new 2 5/16 inch with a new jack and all. When you do get the jack off, you will need to file the hole bigger, beause the new jacks are larger in diameter.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 06-23-2004, 02:43 PM   #9
dmreilly10000's Avatar
1953 25' Cruiser
Brandon (near reservoir) , Mississippi
Images: 14
As some others have suggested, a grinder is your best bet. I replaced the jack on my 1953 Cruiser and had to grind off the rivets.
dmreilly10000 is offline   Reply With Quote
Old 06-23-2004, 02:56 PM   #10
RichardT's Avatar
The easiest way is to use a cutting torch, heat the rivits up and they will melt and can be knocked out with a hammer and punch this will not hurt the surrounding metal at all if you are carefull.
RichardT is offline   Reply With Quote
Old 06-23-2004, 09:37 PM   #11
Over59's Avatar
Images: 37
The coupler is prone to not being secure. Prehaps I'll replace the whole thing when the cross member in the back and the black/grey tank supports are put in. Less to worry about down the road.
Old 06-24-2004, 12:04 AM   #12
greg176's Avatar
Gabriola Island , British Columbia
The front of that coupler looks like it is bent forward about 30 degrees and is that a rather large crack behind the tongue jack.I'd change that coupler now.
greg176 is offline   Reply With Quote
How do you manually crank a Super Jack flyfisher Jacks, Stabilizers, Lifting and Leveling 7 06-20-2011 08:53 AM
Electric/Manual Jack Security Question docbluedevil Jacks, Stabilizers, Lifting and Leveling 1 11-01-2003 11:50 PM
Moving the camper without the front jack wheel Silvertwinkie Our Community 9 07-22-2003 06:46 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
