Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 08-02-2008, 05:47 PM   #1
BigMike
Profile:  1977 Argosy 24
Jack Points "77" Argosy 24
I need to jack-up my trailer and switch out some wheels.......where are the "jack Points" on this unit......??
Is it ok to jack it up under the axels??.....where to place the jackstands??
Thanks...... Big Mike
BigMike is offline   Reply With Quote
Old 08-02-2008, 06:01 PM   #2
easyride
Profile:  1977 27' Overlander
naples , Florida
Easiest way is to pull 1 axle up on 2x8 made into a ramp about 6" high,that leave other axle hanging.Yes you can jack between axles.look under for reinforfed part of frame [where axles mount]and you can put your jack stands under there.Dave
easyride is offline   Reply With Quote
Old 08-02-2008, 06:28 PM   #3
BigMike
Thanks................
Old 08-02-2008, 06:35 PM   #4
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by BigMike View Post
...Is it ok to jack it up under the axels??...
hi bigmike
under the axles, NO
between the axles on the mounting bracket/rail yes...
on use the factory jack points noted in this thread...
http://www.airforums.com/forums/f457...eam-18435.html
for a single wheel on a multiaxle unit a ramp is an easy safe approach.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Any 1976 Argosy 26'ers with "hard rear spare tire covers" that anyone knows of? J. Lee Turne Argosy Motorhomes 3 06-30-2008 08:27 AM
Hubcap search -- looking for "dog bowl" or "baby moon" hub caps yukionna For Sale & Wanted 5 07-26-2004 05:44 PM
Placing the jack under the "arm"? Kistler Jacks, Stabilizers, Lifting and Leveling 0 03-18-2004 03:26 PM
