Old 03-15-2019, 03:13 PM   #1
2000 30' Excella
Paris , Ontario
Jack not working
Went to get trailer out of storage (outside all winter ) The jack went up an inch and stopped. I cannot get it to go up or down anymore. Checked the fuses and the battery, all is good. Cannot get the head off to try manually as one Allen key screw is stripped. Any ideas?
Notacottage is offline   Reply With Quote
Old 03-15-2019, 03:26 PM   #2
2007 22' International CCD
Jack not working
Bottle jack or other jack to support the a-frame. Pull the three bolts out of the jack base. Hook up and go.
Troubleshoot on the bench. If itís not the switch, check the motor and limit switches.
All else fails, get a new one.
I try to keep a waterproof cover over mine...they really donít do well out in the rain.
rmkrum is online now   Reply With Quote
Old 03-15-2019, 05:49 PM   #3
Mollysdad's Avatar
Things to try.
1. Does the light come on? If yes, it's getting power
2. Is the ground good? I tried a jumper cable between my battery negative and the exposed shaft. All jacks get their ground through the three bolts between the jack and frame. Rust is an enemy.
Old 03-15-2019, 07:58 PM   #4
2000 30' Excella
Paris , Ontario
good ideas thanks
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 4 04-03-2016 09:16 PM
Power Jack/Control panel not working TinLiz Towing, Tow Vehicles & Hitches 5 06-27-2012 11:41 AM
Electric Jack Not Working eberrobw Jacks, Stabilizers, Lifting and Leveling 13 03-13-2012 11:23 PM
Elec Stab Jack Not working Coloradoair Jacks, Stabilizers, Lifting and Leveling 22 03-15-2011 11:42 PM
