Old 10-23-2014, 11:35 AM   #1
waynedonald's Avatar
2001 34' Limited S/O
milton , Florida
Jack needs to be adjusted
Does anyone know if a Barker jack up & down height be ajusted?
My jack will only go up or down about 10''.
Thanks, Wayne
waynedonald is offline   Reply With Quote
Old 10-23-2014, 11:46 AM   #2
daveswenson's Avatar
2012 28' International
Olympia , Washington
Will it go farther if you raise or lower it manually. It could be you are hitting the limit switch of the motor prematurely. You can adjust the limit switches by manually moving the jack to just short of it's upper limit, then removing the power head, run it until the limit switch shuts off the motor and then reinstalling.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 10-23-2014, 12:13 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
There are 2 limiting factors to the jack. The mechanical limit is fixed by the machining within the jack shaft. The electrical limit is set by 2 limit switches in the motor.
Run the jack to the retracted limit using the motor. Remove the motor head and using the hand crank retract the jack to it's mechanical limit. Now extend the jack using the crank handle1 1/2 turns. Replace the motor head. This offset is a safety factor.
You motor head should now move the jack through it's full range.
Sounds like someone may have removed the motor head at some point while the shaft was not at either extension and got things out of sync.
2004 Excursion 4x4
Old 10-23-2014, 03:06 PM   #4
milton , Florida
Thanks for the information.
Wayne
Adjusted the ball and hitch today Lucky Dog Hitches, Couplers & Balls 15 03-30-2011 11:03 AM
How are elec. trailer brakes adjusted?? the ponz Brakes & Brake Controllers 8 04-17-2005 06:41 AM
Jack needs replacing Zmod Jacks, Stabilizers, Lifting and Leveling 7 06-04-2004 05:06 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
