Old 04-10-2016, 02:46 PM   #1
2008 27' Safari FB SE
Delta , BC
Jack needed to lift trailer after a flat
What type of jack do people carry in case they do happen to have a flat? Do you store it in the trailer or the tow vehicle?
bugman3 is offline   Reply With Quote
Old 04-10-2016, 03:14 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
For a double axle trailer no jack needed. Theoretically I use my Anderson Levelers on one wheel only.
MICHAEL
Old 04-10-2016, 03:31 PM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I used to carry a floor jack (trolley type) with jackstands. Lots of space as I tow with a pickup.
But then I found (as Michael says above) that there is no need for a jack.
I use Lynx Levellers and drive one wheel up onto a pyramid of them, then the adjacent wheel is hanging free in mid air ready to be removed. Only applicable of course on a dual axe trailer.
I find this to be quicker and, I believe, safer than using jacks.
Loosen the lug nuts slightly before the wheel is off the ground - a lot easier! I tighten with torque wrench once back on the ground, then re-torque about 5 miles down the road.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 04-10-2016, 04:26 PM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Take a look at the jack for your TV. you might be surprised at how capable that jack is if its like the jack found in most pickups.
I can lift my 9000 lb 30' trailer with the jacks from 2 1 ton pickups, that's all 4 tires in the air, 1 per side.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 04-10-2016, 05:20 PM   #5
Delta , BC
Thanks, sure easier than carrying the heavy jack.
Old 04-10-2016, 05:47 PM   #6
2005 19' Safari
GLENDALE , AZ
After a blowout and getting stuck in soft sand up to our single-axle Bambi's frame, we carry a floor jack.
We used to have a two ton floor jack, but when attempting to jack up a tire after another blowout (this time on our TV), the two ton model was unable to lift the rear tire of our TV with our Bambi still attached and the truck bed full of camping gear. Consequently, we now carry a three ton hybrid aluminum/steel floor jack (Costco, approximately $100).
The new jack is probably overkill, but the old one was useless. I had to call a tow truck to change the tire, partially due to the dangerous location on an Interstate, where the blowout occurred.
Old 04-10-2016, 06:51 PM   #7
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I've lifted our trailer with the Jack from our tundra several times with no problem. Keep in mind that you're not lifting the entire weight of the trailer, just one side at a time.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 04-10-2016, 07:51 PM   #8
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
We saw a fellow changing a tire on a fifth wheel trailer. He was having a very hard time getting it high enough to pull the tire off. Lesson - Be sure to pack a couple of blocks to add vertical height and some plywood plates to spread the load if the ground is soft. A credit card or roadside assistance coverage is an alternative that is easier on the back. Pat
Might need a digging tool to make room for the jack if the coach is in a hole. Not a bad idea to clear a path if it snows either.
Old 04-10-2016, 09:52 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
IMHO the best jack for on the road repairs is a hyd bottle jack, hands down.
Safe, compact, light, and versatile.
Superat stultitia.
Old 04-10-2016, 09:59 PM   #10
spenfolder's Avatar
2006 16' International CCD
Salt Lake City , Utah
I use my "scissors" jack included with my Jeep. It works well so I don't need to carry an extra. I have found that a 1 foot 2x4 helps get that extra inch I need. I have a 16' single axle, so the drive up on blocks trick doesn't work for me. Thankfully, I have only had to deal with one blowout on the side of a freeway. But that is another story. Let me just say, I no longer run on GY Marathons.
Stan
Salt Lake City
Stan
Salt Lake City
spenfolder is offline   Reply With Quote
Old 04-10-2016, 10:03 PM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Second on the bottle jack. Lego blocks are best for a dual axle trailer, but only if you are hooked up and can move the trailer. Have done that.
Found a nail after being set up for a couple of days. Was great to have the bottle jack.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-10-2016, 10:03 PM   #12
jump's Avatar
2013 30' International
lubbock , Texas
Camco trailer aid
This is what I use
When at Discount tire for flat repair, I ask them to use it, also
jump is offline   Reply With Quote
Old 04-11-2016, 10:40 AM   #13
HCR
HCR's Avatar
Livingston , Full time traveler
Trailer -Aid as pictured in earlier post. Small, light-weight and effective.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 04-11-2016, 11:36 AM   #14
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by jump View Post
This is what I use
Attachment 260400
What he said^^^
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
1997, 34ft Classic: To Lift, or Not To Lift (its shell) mattler General Repair Forum 4 10-16-2015 10:40 PM
Got a flat, where do I jack? Dan S Tires 10 05-26-2014 10:38 AM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
Where to place jack to lift trailer BDD2939 Jacks, Stabilizers, Lifting and Leveling 1 03-02-2011 03:25 PM
'77 Argosy, should I jack because tires flat? saxonsraven1 Mechanics Corner - Engines, Transmission & More... 1 01-26-2004 02:18 PM
