04-10-2016, 02:46 PM
2008 27' Safari FB SE
2023 28' Pottery Barn
Delta
, BC
Jack needed to lift trailer after a flat
What type of jack do people carry in case they do happen to have a flat? Do you store it in the trailer or the tow vehicle?
04-10-2016, 03:14 PM
Biloxi
, Mississippi
For a double axle trailer no jack needed. Theoretically I use my Anderson Levelers on one wheel only.
MICHAEL
04-10-2016, 03:31 PM
2005 30' Classic
Burlington
, Ontario
I used to carry a floor jack (trolley type) with jackstands. Lots of space as I tow with a pickup.
But then I found (as Michael says above) that there is no need for a jack.
I use Lynx Levellers and drive one wheel up onto a pyramid of them, then the adjacent wheel is hanging free in mid air ready to be removed. Only applicable of course on a dual axe trailer.
I find this to be quicker and, I believe, safer than using jacks.
Loosen the lug nuts slightly before the wheel is off the ground - a lot easier! I tighten with torque wrench once back on the ground, then re-torque about 5 miles down the road.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
04-10-2016, 04:26 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Take a look at the jack for your TV. you might be surprised at how capable that jack is if its like the jack found in most pickups.
I can lift my 9000 lb 30' trailer with the jacks from 2 1 ton pickups, that's all 4 tires in the air, 1 per side.
04-10-2016, 05:20 PM
Delta
, BC
Thanks, sure easier than carrying the heavy jack.
04-10-2016, 05:47 PM
2005 19' Safari
GLENDALE
, AZ
After a blowout and getting stuck in soft sand up to our single-axle Bambi's frame, we carry a floor jack.
We used to have a two ton floor jack, but when attempting to jack up a tire after another blowout (this time on our TV), the two ton model was unable to lift the rear tire of our TV with our Bambi still attached and the truck bed full of camping gear. Consequently, we now carry a three ton hybrid aluminum/steel floor jack (Costco, approximately $100).
The new jack is probably overkill, but the old one was useless. I had to call a tow truck to change the tire, partially due to the dangerous location on an Interstate, where the blowout occurred.
04-10-2016, 06:51 PM
1977 23' Safari
Niagara on the Lake
, Ontario
I've lifted our trailer with the Jack from our tundra several times with no problem. Keep in mind that you're not lifting the entire weight of the trailer, just one side at a time.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
04-10-2016, 07:51 PM
Walnut Creek
We saw a fellow changing a tire on a fifth wheel trailer. He was having a very hard time getting it high enough to pull the tire off. Lesson - Be sure to pack a couple of blocks to add vertical height and some plywood plates to spread the load if the ground is soft. A credit card or roadside assistance coverage is an alternative that is easier on the back. Pat
Might need a digging tool to make room for the jack if the coach is in a hole. Not a bad idea to clear a path if it snows either.
04-10-2016, 09:52 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
IMHO the best jack for on the road repairs is a hyd bottle jack, hands down.
Safe, compact, light, and versatile.
Superat stultitia.
04-10-2016, 09:59 PM
2006 16' International CCD
Salt Lake City
, Utah
I use my "scissors" jack included with my Jeep. It works well so I don't need to carry an extra. I have found that a 1 foot 2x4 helps get that extra inch I need. I have a 16' single axle, so the drive up on blocks trick doesn't work for me. Thankfully, I have only had to deal with one blowout on the side of a freeway. But that is another story. Let me just say, I no longer run on GY Marathons.
Stan
Salt Lake City
Stan
Salt Lake City
04-10-2016, 10:03 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
Second on the bottle jack. Lego blocks are best for a dual axle trailer, but only if you are hooked up and can move the trailer. Have done that.
Found a nail after being set up for a couple of days. Was great to have the bottle jack.
2004 31' Classic
lubbock
Camco trailer aid
This is what I use
When at Discount tire for flat repair, I ask them to use it, also
04-11-2016, 10:40 AM
Livingston
, Full time traveler
Trailer -Aid as pictured in earlier post. Small, light-weight and effective.
Airstream of Consciousness
04-11-2016, 11:36 AM
2013 30' Classic
Greenwood
, Mississippi
Originally Posted by jump
This is what I use
Attachment 260400
What he said^^^
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
04-11-2016, 11:37 AM
2019 25' Flying Cloud
Sequim
This is what I use
Attachment 260400
I used this on my 2nd trip out last year when I caught a screw on the road in MT. It worked like a charm even though I had only read how to do it. Have a torque wrench with you - it is as important as a jack to be sure the tire you install stays in pkace!
04-11-2016, 12:05 PM
Moderator dude
1966 26' Overlander
Phoenix
On your double axle trailer ....
Chunks of 2 X 6 wood. Old school and cheap.
Role the good axle up and the bad tire dangles. Don't forget to loosen the lug nuts or bolts before the tire leaves the ground.
>>>>>>>>>>>>>>Action
04-11-2016, 12:36 PM
2013 30' Classic
Greenwood
, Mississippi
Or a length of 6x6 post cut on a diagonal = homemade trailer aid ramp-
This is what we have in 20 trailers at work.
TAC #MS-10
Airforums #70955
04-11-2016, 01:10 PM
2014 31' Classic
Hot Springs
, Arkansas
Trailer Jack
I'd also like to plug a good roadside assistance plan. Had a blowout on our 14 Classic and Good Sam had me back on the road in less than an hour. About $79 a year. Have the ramps to drive up in in an emergency.
04-11-2016, 01:33 PM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
The only blow-out we've experienced showed us that the scissor jack that came with the Expedition was a POC. I've since been carrying a bottle jack in the TV.
04-11-2016, 01:44 PM
2007 28' International CCD
Springfield
, Missouri
I use Lynx levelers.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
1997, 34ft Classic: To Lift, or Not To Lift (its shell)
mattler |
General Repair Forum |
4 |
10-16-2015 10:40 PM |
Got a flat, where do I jack?
Dan S |
Tires |
10 |
05-26-2014 10:38 AM |
Air 'Bags' - too lift or not to lift
JourneytoRet |
Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes |
5 |
04-09-2013 10:09 AM |
Where to place jack to lift trailer
BDD2939 |
Jacks, Stabilizers, Lifting and Leveling |
1 |
03-02-2011 03:25 PM |
'77 Argosy, should I jack because tires flat?
saxonsraven1 |
Mechanics Corner - Engines, Transmission & More... |
1 |
01-26-2004 02:18 PM |
