Old 04-11-2016, 11:37 AM   #15
2015 23' FB Flying Cloud
Redmond , Washington
Originally Posted by jump View Post
This is what I use
Attachment 260400
When at Discount tire for flat repair, I ask them to use it, also
I used this on my 2nd trip out last year when I caught a screw on the road in MT. It worked like a charm even though I had only read how to do it. Have a torque wrench with you - it is as important as a jack to be sure the tire you install stays in pkace!
WestieHouse is offline   Reply With Quote
Old 04-11-2016, 12:05 PM   #16
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
On your double axle trailer ....
Chunks of 2 X 6 wood. Old school and cheap.
Role the good axle up and the bad tire dangles. Don't forget to loosen the lug nuts or bolts before the tire leaves the ground.
>>>>>>>>>>>>>>Action
Old 04-11-2016, 12:36 PM   #17
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Or a length of 6x6 post cut on a diagonal = homemade trailer aid ramp-
This is what we have in 20 trailers at work.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-11-2016, 01:10 PM   #18
2014 31' Classic
Hot Springs , Arkansas
Trailer Jack
I'd also like to plug a good roadside assistance plan. Had a blowout on our 14 Classic and Good Sam had me back on the road in less than an hour. About $79 a year. Have the ramps to drive up in in an emergency.
Gigi1957 is offline   Reply With Quote
Old 04-11-2016, 01:33 PM   #19
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
The only blow-out we've experienced showed us that the scissor jack that came with the Expedition was a POC. I've since been carrying a bottle jack in the TV.
banderabob is offline   Reply With Quote
Old 04-11-2016, 01:44 PM   #20
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I use Lynx levelers.
Old 04-11-2016, 03:09 PM   #21
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
x2 on the Lynx levelers. Had the Trailer Aid (came with trailer) sold it. Saw no reason in having both and you do need the levelers. Had a blow out on the Interstate a while back, pulled the trailer up on the levelers and had the spare on and back on the road within 15 minutes. The levelers are just as safe if connected to TV while changing tires.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 04-11-2016, 03:18 PM   #22
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Primarily I use Lynx levellers, but I do also carry a bottle jack and a few bits of wood "just in case!"
For example - if my electric tongue jack quits and for some reason I cannot wind it manually with a wrench, then at least I could easily employ the bottle jack and remove / replace the defective tongue jack that is bolted in place on the tongue.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 04-11-2016, 05:14 PM   #23
2007 25' Safari
Attleboro , Massachusetts
I use a similar ramp type that I got at Speedway Motors. I've read that you shouldn't jack the trailer up by the axle but even so the ramp is small light and very easy to use. Only thing (don't ask me how I know) is do not unhook the trailer while it's up on that ramp
romeb is offline   Reply With Quote
Old 04-12-2016, 11:52 AM   #24
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
A trailer can be jacked up under the axle mounting bracket or under the trailer frame. Never jack under the axle tube itself.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 04-12-2016, 02:33 PM   #25
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
My first Airstream was 1973 30' (or 31' can't remember) It came with a wooden wedge to drive one tire onto when there was a flat tire on another. The attachment is a page out of an Airstream owner manual that addressed how to use that wedge. I've made one of these for each trailer I've owned.
I carry a wood wedge and a bottle jack. Between the two I've never been unable to raise my trailer when I needed. At one time I used a floor jack at home, but I no longer do that.
jack - trailer wedge.pdf
Old 04-12-2016, 11:28 PM   #26
jrolls's Avatar
2005 30' Classic
Brigham City , Utah
Following the owners' manual, Wingezzer's response is a 'no brainer' for dual axle trailers. Never had to consider it until last summer between Bishop CA and Wendover NV (the middle of nowhere with NO cell signal). Our 1st ever flat in 10+years, and my wife and I had the spare mounted, and we were on the road in less than 45 minutes! I guess there may be situations calling for a 'proper' jack, but for us our Lego blocks, a breaker bar and torque wrench were all we needed.
jrolls is offline   Reply With Quote
Old 04-13-2016, 12:46 AM   #27
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Trailer aid, Anderson levelers and a 5 ton bottle jack. Pieces of 2x4 are your friend.
1997, 34ft Classic: To Lift, or Not To Lift (its shell) mattler General Repair Forum 4 10-16-2015 10:40 PM
Got a flat, where do I jack? Dan S Tires 10 05-26-2014 10:38 AM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
Where to place jack to lift trailer BDD2939 Jacks, Stabilizers, Lifting and Leveling 1 03-02-2011 03:25 PM
'77 Argosy, should I jack because tires flat? saxonsraven1 Mechanics Corner - Engines, Transmission & More... 1 01-26-2004 02:18 PM
