Old 05-06-2007, 09:38 AM   #1
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
Jack mounting plate
Hello All
A couple of things to ask. My electric jack stopped jacking. The motor works fine but it must have lost its grip on the thread as now it neither raises or lowers. I took the jack off to see if it could be fixed and found the mounting to be a 'little' worn (see attached pictures)
It appears to hold the tongue weight of a 31ft 73 soveriegn (600-800lbs) no problem, but seeing this is a concern.
I've searched the forums and found little information about this issue. There is mention of coupler replacement, so replacing the whole thing is an option, but if it's possible to weld some sort of attachment would that work?
I'm also thinking of a replacement electric jack that includes manual operation, any suggestions
Sincerely
ID:	36946   Click image for larger version
elbundi is offline   Reply With Quote
Old 05-06-2007, 10:14 AM   #2
Dwight's Avatar
1999 34' Excella
Joshua , Texas
plate...
After you clean up and have cut away the rusted areas, just cut a piece of 1/8" steel plate to fit, then weld it on all sides and grind the welds smooth.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 05-06-2007, 10:29 AM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
My '73 27' manual jack displays no similar corrosion (whew) after a panic check a minute ago; man-o-man count yourself lucky that didn't punch through, say, trying to lift off your tow rig that just had a flat or breakdown, or other nightmare, say at leaving fully booked campground, etc..
A manual jack mechanism is twenty to fourty spins that seem to go easier the faster it is spun. I lube the mechanism with pintle-hook spray lube from lubri-plate that is gnarliest formulation I've found as it dries rapidly into a damp paste that doesn't attract grit. I remember the mechanical leverage is different on dual-action jacks; probably more turns required on the electric for same lift - that might be a valid sales point...
Old 05-06-2007, 11:33 AM   #4
1984 31' Excella
Norfolk , Virginia
Images: 11
Coupler
Man are you lucky. From the pictures it looks bad.
The coupler is welded in place, so it can be removed by cutting?grinding through the welds and a new one welded on.
I'vve replaced these on other various trailers that were also welded on.
Recommend two things.
1. Ask other Vintage owners where they got their couplers from and check prices. Your present coupler is probally worn.
2. Have the final welding done by a Certified Welder for two reasons,
A. They know what their doing.
B. They carry insurance to cover mistakes
Ask around your community/town/county. There will be a shop or person that will surface that has been doing that service for years and is reasonable and might iven come to your house to do it for a nominal charge. I know of one of these in my area.
Beginner
Beginner is offline   Reply With Quote
Old 05-06-2007, 05:55 PM   #5
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I think it would be a good idea to replace the coupler. It cost me $50 to have a welder come to my home to weld on a new coupler. I had removed the old one before he arrived.
If I hadn't already replaced mine your picture would have sent me out to check it. I'd hate to think what would happen if the jack gave way and the tongue came down on your foot!
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 05-06-2007, 06:24 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Cinder-ella
BTW a cinderblock is NOT a good idea used in the manner shown in your picture. Uneven pressure can cause them to fail catastrophically with no warning what-so-ever. Please, get an automotive jackstand instead. We'll all breath easier
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-06-2007, 07:44 PM   #7
1984 31' Excella
Norfolk , Virginia
Images: 11
Cinder Block
Missed that.
That tongue could go right through that web any minute.
If you must use cinderblocks then place a 2x8 on top of the cinder block covering all the side that is load bearing (in this case 8x8") to properly spread out the load.
Bdtter yet use two cinderblocks and use a 2x16" board to spread out the load even better.
Best: Jack Stand as previously stated.
I have seen people killed when using cinder blocks without the 2xwhatever to spred out the load evenly on the whole top of the cinter block.
Beginner
Old 05-06-2007, 08:46 PM   #8
elbundi's Avatar
Leesburg , Georgia
re: cinder block
thanks for the concern guys. that cinderblock/breezeblock is filled with heavy duty concrete. it was from some wide eyed project a while back and just happened to be around. see attachment. i think the load balance is ok, but good call on the automotive jack. i'll be running by the auto store tomorrow.
tonight i ordered a FULTON A-Frame Trailer Coupler, 10k Capacity for $39.95 and will be calling on a local certified welder tomorrow, see how their schedule looks.
thanks for all your help.
i hope my luck will have encouraged those with older trailers to check their own couplers if they havent already done so.
sincerely
Old 05-06-2007, 10:08 PM   #9
Excella CM's Avatar
Venice , California
I'm glad you had a good, solid reason for using that block.
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
TV Connection Plate winner Audio, Video & TV 10 06-16-2002 06:00 PM
