Old 07-15-2013, 09:53 AM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Jack motor
The tongue motor stopped working, tore it down all other parts are fine, should I just have the motor rebuilt by local shop.....or buy one.
It's the original '77, no brand or make anywhere on it.
'77 Sovereign Intl 31' CB
Old 07-15-2013, 10:00 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Get local rewire!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-15-2013, 10:08 AM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Are you sure the problem isn't just a bad ground or connection somewhere? I had that happen on two trailers!
In both cases my problem turned out to be corroded wires under wire nuts. When I checked with a multimeter at the motor, it seemed to be getting 12v, but the connection was so bad that it could not draw sufficient current to operate. When I connected the motor directly to a 12v battery it ran fine, so that go me looking into the feed wiring and that was how I discovered the problem.
I cleaned the wires up and soldered them rather than just relying on wire nuts. been ok ever since.
Just a thought - probably you have already checked this!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-15-2013, 10:16 AM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
yep tried it
Old 07-15-2013, 10:17 AM   #5
Kevin245's Avatar
I'm not sure if this will help in your case, but the jack on our Avion stopped working several years ago. I took it apart and found that the motor armature would not spin because moisture (condensation) had built up in the lower part of the motor. This caused the armature to seize in the bearing sleeve. Some WD40 and a fine steel wool massage of the armature did the trick and the unit is still in service today.
Eleanor Roosevelt
Old 07-15-2013, 10:19 AM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
the armature turns
Old 07-15-2013, 10:57 AM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
Since you are into the motor did you try applying power directly to the motor? Get the end switches out of the circuit. If the motor work under this condition one of the end switches may have overrun and be open.
2004 Excursion 4x4
Old 07-15-2013, 11:15 AM   #8
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Jacks are cheap on ebay.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 07-15-2013, 11:28 AM   #9
SteveH's Avatar
Common Sense , Texas
Just my opinion, but I would not attempt to repair a 36 year old electric tongue jack. I would replace it in a heartbeat.
Regards,
Steve
Old 07-15-2013, 01:00 PM   #10
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Perhaps that's because you're not into vintage aka the VAC, we try and fix things rather than just replace.
Airstreams are not planned obsolescence.
Old 07-15-2013, 01:11 PM   #11
SteveH's Avatar
I understand that, and your point. But, if you get the motor repaired, what's the next thing that's going to break in that 36 year old jack, and will you be able to buy that part?
You could buy a new one, and paint it the same color as the old one.
Regards,
Steve
Old 07-15-2013, 01:14 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If fixable, do it. Also, this is a great time to verify the jacking parts are safe. A great deal of wear happens in the screw, too. If still good, rewire motor.
There are folks who can help. If you can't find, PM me and I will point you toward someone who rebuilds several thousand HP to specialty motors.
Channing
WBCCI# 30676
Old 07-15-2013, 01:54 PM   #13
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Thumbs up
Bingo, that was it.
Now how to find that or substitute switch.
It says 10A 250 vac
1/4 hp 125-250 vac
I think temporally I just run two wires out to 12v and jump up or down.
tks Howie
Old 07-15-2013, 02:04 PM   #14
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
I always get into more ancillary things when I take stuff apart, you're correct.
