Old 10-26-2018, 06:47 PM   #1
Pearl , Alaska
Jack e up installed...
My first mod on my Bambi 16 Sport and I’m happy with the results. This allows removal of jack from trailer by just a quarter turn. Spend a lot of time hooked up and this allows me to lower my truck bed for easy access...
60 bucks at Northern Tool...
Quarter turn and jack is back in place
Store in my TV.
ID:	326365Click image for larger version
Deltaboy59 is offline   Reply With Quote
Old 10-26-2018, 07:00 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Very cool. I've not seen that before. My utility trailer has one of those manual tongue jacks that is mounted about where your propane tanks are, and then I can pull the pin and rotate the jack 90 degrees. This allows the truck tail gate to go all the way down.
Nice upgrade and will save a scratch on the tail gate if it got away from you.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 10-27-2018, 12:24 PM   #3
Msherw's Avatar
2018 22' Sport
Blue Sky Ranch , Texas
Nice add on. My TV is an SUV with a swing up back door. 3" clearance so not needed. But someday a PU may be the TV. Thanks for sharing.
M!ke
2019 Tiffin Wayfarer 24TW
Ham Radio Call sign K5FT
Msherw is offline   Reply With Quote
Old 10-27-2018, 03:44 PM   #4
2011 22' Sport
Portland , Oregon
Interesting fix, haven’t seen that before. Just don’t forget the jack at home! Or set it in the ground at the CG before departing.
SilverHouseDreams is offline   Reply With Quote
Old 10-29-2018, 11:05 AM   #5
2018 22' Sport
Evans , Georgia
We have the Jack-E-Up also. We keep all the setup type tools in the bed of our pickup truck. Saves space on the Airstream. Facilitates setup and organization when arriving and leaving the campsite.
DaveAndJane is offline   Reply With Quote
Installed new E Tongue Jack, now propane tank cover won't fit cgseanp Jacks, Stabilizers, Lifting and Leveling 16 11-20-2023 07:38 AM
Anyone installed leveling jacks over Jack points? Snowy Jacks, Stabilizers, Lifting and Leveling 11 06-06-2017 04:40 AM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
