Old 06-02-2015, 07:52 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Jack
I just found out that AS does not supply a jack. So what kind of jack do you use for changing tires?
Or do you use roadside service?
Hans627 is online now   Reply With Quote
Old 06-02-2015, 07:55 PM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I carry one of these:
AlltradeTools - Catalog - 640912 3 Ton All-In-One Bottle Jack/Jack Stand
It is placed between the wheels and lifts on the frame doubler. I have lifted our 31' Classic with one to do the initial tire swap to Michelins.
Old 06-02-2015, 08:00 PM   #3
firstwave's Avatar
2006 30' Classic
Santa Fe , New Mexico
Trailer Aid Plus Tandem Tire Changing Ramp
These are pretty handy if you need to change a flat.
Amazon.com: Trailer Aid Plus Tandem Tire Changing Ramp: Automotive
Name:	Trailer Aid Plus Tandem Tire Changing Ramp.jpg
firstwave is offline   Reply With Quote
Old 06-02-2015, 08:11 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have had a number of tire failures over the years on tandem axle Airstreams. We have always use lego blocks (lynx levelers) to change tires on the highway. We have also used them to put our new 16" wheels on Lucy.
Brian
SuEllyn & Brian McCabe
Old 06-02-2015, 08:24 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Works for me,
https://www.andersenhitches.com/Prod...r-leveler.aspx
MICHAEL
Old 06-02-2015, 08:25 PM   #6
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I carry a bottle jack in my van (which also works for the van). I would need it if I ever have a flat as I have a single axle trailer. I lift at the axle plate, not back at the ridiculous marked "jack point" which is towards the back of the trailer.
robert claus is offline   Reply With Quote
Old 06-03-2015, 06:55 AM   #7
switz's Avatar
2014 31' Classic
Images: 8
When jacking to replace the front tire on a tandem axle rig, I found if I extend the tongue jack I can get both wheels off the ground at the same elevation, otherwise when the rear tire is clear, the front is still touching the ground.
Old 06-03-2015, 03:49 PM   #8
Hans627's Avatar
Thanks! Several good options. I'm feeling a little better about the jack situation now!
Old 06-03-2015, 03:55 PM   #9
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I use the same Lynxleveler blocks that I carry for my leveling and stabilizers.Very handy I carry two sets.
http://www.walmart.com/ip/Lynxlevele...ng-Kit/1677842
Old 06-03-2015, 05:45 PM   #10
ckottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We carried a bottle jack, Trailer Aid ramp, and leveler blocks at first. Have wised up with experience and now only the leveler blocks, they are multi-pupose. Tire changing ramp, side-to-side leveler, blocks under stabilizers, tires, and tongue jack on soft ground. We have gained storage space and lightened our load, both a goal for Airstreamers.
Changing to Michelin 16" LTX tires has helped prevent ever having to change a tire in six years of many, many coast-to-coast and border-to-border trips about the country.
For those reasons we see no use for anything but leveler blocks, with a set of X-chocks to secure the trailer from moving, especially on sloped parking sites.
cheryl
ckottum is offline   Reply With Quote
Old 06-03-2015, 06:05 PM   #11
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
We have been carrying 3 sets of Lynx blocks and one Trailer Aid ramp...but maybe we can make do with just the blocks.
Rocinante is our 2014 International Signature 27FB
Rocinante is online now   Reply With Quote
Old 06-03-2015, 06:34 PM   #12
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Originally Posted by AWCHIEF View Post
Ditto +1
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
To Jack or not to jack? Zstream Jacks, Stabilizers, Lifting and Leveling 7 12-17-2009 11:09 AM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
B.A.L. Jack TheBigRedTruck Jacks, Stabilizers, Lifting and Leveling 4 06-06-2002 01:34 PM
Jack Point 74Tradewind Jacks, Stabilizers, Lifting and Leveling 1 05-15-2002 06:27 PM
