Old 01-10-2019, 09:32 AM   #1
2019 22' Sport
Bellingham , Washington
Installing Electric Trailer Jack
I just purchased the Husky 5,000 lb electric trailer jack, probably overkill for my 2019 Sport 22, but the price was great. Looking at the instructions everything is straightforward. To attach to the battery do I need to drill a hole through the plastic battery cover?
https://www.rvautoparts.com/82022-Hu...BoCB5QQAvD_BwE
kmclaren is offline   Reply With Quote
Old 01-10-2019, 01:08 PM   #2
2015 16' Sport
Lakeridge , Virginia
No drilling required. Just feed the wire through the same place the battery cable feeds. I zip tiied mine to the cable.
Peanut is offline   Reply With Quote
Old 01-10-2019, 01:45 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you can install the fuse in the line inside the battery case. This will give the max. protection should the jack feed wire ever short to the chassis.
If a fuse did not come with the jack get a 30 amp inline fuse and holder and use #12 wire.
2004 Excursion 4x4
Electric trailer Jack roadkill367 Jacks, Stabilizers, Lifting and Leveling 12 08-14-2018 05:59 PM
Installing a new electric jack ChuckZ General Repair Forum 8 08-13-2016 06:40 PM
Want Electric Jack for Argosy 20' Trailer Elisa All Argosy Trailers 18 02-24-2015 03:25 PM
Trailer front electric jack mocus Towing, Tow Vehicles & Hitches 29 07-29-2012 02:21 PM
Installing a new ultra 3002 electric tongue jack on my 65 Caravel toastie Jacks, Stabilizers, Lifting and Leveling 3 03-15-2007 11:10 AM
