Old 03-13-2007, 04:57 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Installing a new ultra 3002 electric tongue jack on my 65 Caravel
Getting ready to install a new Ultra 3002 electric tongue jack on my 1965 Caravel, the old is on it's last leg. The old, is a 2" dia held on with 3 bolts, the 2" then runs thru a bottom plate, and the bottom plate is welded to the frame, my question is, was that typical for airstream to build it that way?. It appears that I will have to cut out the bottom plate and hope that the ass'y come off, has anybody out come across this same problem...........thanks
toastie is offline   Reply With Quote
Old 03-14-2007, 10:44 AM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
You shouldn't need to fool with the bottom plate - the shaft just goes through it. At least on mine. The three bolts go into threaded holes - no nuts involved.
Pat
pmclemore is offline   Reply With Quote
Old 03-14-2007, 10:50 AM   #3
toastie's Avatar
1955 22' Safari
Pat
Was yours a tight fit, mine looks like a press fit, they also welded the chains to the bottom plate and the 2" dia tube that passes thru the bottom plate.
Was yours hard to get take off...........
Old 03-15-2007, 11:10 AM   #4
Ready-to-Travel
pmclemore's Avatar
toastie,
I see that yours is a vintage model - mine is much newer. But with mine, I just sprayed some penetrating oil, then lowered the tongue onto jacks and removed the jack. I remember worrying about the lower part (plate) but it turned out not to be an issue at all. The fit was tight, but didn't require a press.
I'd suggest just giving it a shot - trying the easy way to remove it. If it won't, then you'll have to find someone who knows what he's talking about...
Karma for your efforts!
Good luck - Pat
caravel
another Caravel owner davidw 1966-68 Caravel 46 02-03-2005 06:53 PM
Another Power Jack Question. 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-15-2002 10:23 PM
B.A.L. Jack TheBigRedTruck Jacks, Stabilizers, Lifting and Leveling 4 06-06-2002 01:34 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
Vintage Ralph Lauren Caravel Sells for $150,000 Andy R Caravel 0 02-22-2002 12:39 AM
