Old 04-09-2014, 04:25 PM   #1
2014 19' Flying Cloud
Cambria , California
Hydraulic jack size?
I purchased a 2014 19ft flying cloud and need to know what size hydraulic jack I need for changing a tire? Walmart has a 2 ton and a 6 ton. Never owed a RV before. Thanks for any help!
The Bambi is offline   Reply With Quote
Old 04-09-2014, 04:50 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A 6 ton would be better. Not because the trailer weighs that much, but because the shaft diameter and base are larger, for more stability.
Old 04-09-2014, 04:58 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The 2 ton will do anything you need with the Airstream. But that said you might just carry the 6 ton for the unexpected.
If you are going to use a hydraulic jack under the trailer you might want to have cups welded at the lift points to keep the jack fro slipping off the frame. 1/4 in. length of pipe a larger diameter than the head of the jack will do the job.
2004 Excursion 4x4
Old 04-11-2014, 08:33 AM   #4
Hydraulic jack size
Thanks for the information. The 6 ton sounds like the way to go.
Old 04-11-2014, 09:17 AM   #5
1974 Argosy 20
Kooskia , Idaho
My experience over the years is that the two ton ones, while sounding like they have the capacity really do not for some reason. So, I add to the pile recommending the larger one. I also like a small floor jack better than the bottle jack, if you have the room for it. They make some with a very small footprint, and they are much more stable than a bottle jack.
Old 04-11-2014, 12:35 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Personally I use the small aluminum floor jack sold by Northern Freight. On sale now. It has been used a lot....makes changing a tire on the road a quick and safe job. Usually less than 50 dollars.
Old 04-11-2014, 01:02 PM   #7
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
What do you tow with? What kind of jack does it have?
The jack for my Tundra works just fine for lifting the Airstream in case of a flat. no need for me to carry doubles of tools.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
No Power to Hydraulic Jack cloudflyer Winterizing, Storage, Carports & Covers 3 03-31-2011 05:28 PM
To Jack or not to jack? Zstream Jacks, Stabilizers, Lifting and Leveling 7 12-17-2009 11:09 AM
Power Jack Breaker Size Rick Alston Electrical - Systems, Generators, Batteries & Solar 4 08-31-2004 11:46 AM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
