Old 05-17-2019, 11:57 AM   #21
Mollysdad's Avatar
For those who are considering turning your jack 90 degrees, this tool might make it easier.
Transfer screws.
It's a set, you'd want the 3/8" x 16 set. Basically it's a collection of threaded inserts with a point, like a punch. You screw one screw in each hole with the point facing up, place your jack in the intended position, and tap the ring with a hammer (dead blow preferred).
That will make a ding in the bottom of the ring everywhere the screws were. Drill out a new hole. They'll match the hole pattern (in theory) I bought my set on e-bay for about $9, but I'll bet ACE or Tru-Value carries them..
The handle on the right is used to store them, chase the threads, and act like a wrench if needed. The points are the tool.
Old 05-17-2019, 03:35 PM   #22
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Originally Posted by Mollysdad View Post
But, in my mind, the extra holes didn't look spaced for a 90 deg. rotation. Is that what you did?
Yes. One set of holes allowed me to turn it 90 degrees. So instead of facing the truck (straight ahead) it's facing the drivers side.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 05-19-2019, 08:32 AM   #23
Masondood's Avatar
2016 30' International
Calgary , Alberta
Originally Posted by LifeIsRiveting View Post
I have the same jack. Works great but I too have tailgate clearance issues. Did not see any apparent way to clock the motor housing 180 degrees. It might look kind of funny but I am considering rotating the whole thing 120 degrees so that there is no need to drill new holes.
We just put on the Husky with remote control, and it is far superior to the stock jack. We have clearance issues with the tailgate on an F350, but just work around.
Michael and Leah
2016 International Serenity 30'- "Suburban Cliche"
2017 F350 Lariat
Poodle and two cats!
Masondood is offline   Reply With Quote
Old 05-20-2019, 05:14 AM   #24
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
We like the Super Jack made by Baker Manufacturing in Michigan. They were used on Airstreams from 1978 to 2007 on the Classic models.
Many from 1978 are still working fine. You can buy parts for it. No plastic parts the cap is cast aluminum. No printed circuits. Will lift the back tires of an F250 off the ground. Nice and compact.
For safety and stability it is best to have the ball as close to the bumper as possible. It is not terribly difficult to relocate the jack behind the LP cover next to the battery compartment.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 05-23-2019, 06:37 PM   #25
1985 25' Sovereign
Red Deer , Alberta
I have read the entire blog but am interested in how much clearance you need. I was tight
By 3/4 “ but was able to get it when I raised the ball on my truck and 11/2 “. It leveled out my trailer and truck AND gAve the clearance I needed. Sorry if this is not what you were looking for but Ithought it might help.
randylar is offline   Reply With Quote
Old 05-28-2019, 04:17 AM   #26
2018 16' Sport
Holland , Michigan
Talking Ame problem solved❗️
Originally Posted by malinois38 View Post
Just received my Husky Super Brute 5000 after some research on the forums. Before I even open the box, can anyone please tell me if the head can be rotated or not? I am not interested in drilling new holes..
My TV is an 2008 Tundra and I need the clearance for the tailgate. I currently have the original jack on my 2008 International and would like more torque when lifting the rear of my vehicle to attach the weight distribution bars.
If the Husky head does not rotate, I will take suggestions on another tongue jack that has 4-5K of torque that does have a rotating head?
Thank You!
Bought a jack that had extra slots so I could rotate it 90* Works good and they have a 5000# one at etrailer.
ID:	341888   Click image for larger version
Flyboy328 is offline   Reply With Quote
Old 05-28-2019, 06:39 AM   #27
"Cloudsplitter"
Originally Posted by jcanavera View Post
Here's a picture of my Husky Brute 5000 on my Classic. One other clearance issue you need to be aware of is the manual crank. If you are ever required to use it, it fits on top of the head. There is a plug in the top that you pull out and then insert the crank into the hole. Nice that unlike the Super Jack, you have no issue with having to resend the gears or pull off the head. The bad side on my trailer is that first, you have to pull the gas bottle cover off and then pull the tanks back to get enough clearance to turn a very big crank handle.
Love the jack though and I feel very good about my selection of this product. The biggest advantage of this jack is that it uses a screw and ball method of raising and lowering the jack. Much more reliable than the geared method and truly is the concept used by heavy lifting jacks used in commercial businesses.
Jack
Jack,
Thanks for the photo...I was concerned about tank cover clearance on the back of the unit.
Does the crank handle fit on a nut or pinned rod?
Could you use an adaptor or socket on an extension with an electric drill or small impact driver?
Head Rotation on Husky #4500 Jack Emh142 Jacks, Stabilizers, Lifting and Leveling 16 08-19-2019 09:03 AM
Husky jack DIY trick Garfish Jacks, Stabilizers, Lifting and Leveling 1 04-13-2019 05:33 PM
Husky Jack Foot Hans627 Hitches, Couplers & Balls 3 04-25-2018 08:50 PM
Atwood Power Jack Replacement (Husky or Barker) Skip Stone 2016 - Current Flying Cloud 1 08-27-2017 11:51 AM
husky jack experience? rumrunner Towing, Tow Vehicles & Hitches 0 08-12-2012 07:55 PM
