Does anyone use the Husky Super Foot that goes on the bottom of your tongue jack? I just put on a Husky jack, just got the super foot and noticed it's a little loose where the bolt goes through the jack tube. The bolt/nut tightened down ok, but is this designed slop for some reason? In case your wondering, it's a 2 1/4" tube and doesn't take the spacer. Input appreciated.
It needs to be lose fitting to fold up and down. Once in the down position it locks there. I had one on my Bambi II with manual jack. Got tired of all the cranking up and down without it. I have seen no need with the current trailer with electric jack.
MICHAEL
It extends the jack by 7 or 8" when needed and retracts aft when not. I didn't like the way it leaned to the side and forward with weight on it.. My wheels were blocked and chocked and it still allowed too much movement for my liking.
The jack foot that came with the trailers with the Super Jack by H & H Engineering a division of Barker extends the jack post 6-8".
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
FYI, this didn't come with the jack, it was another purchase. I went back to the typical round foot that has several holes to allow height adjustment. It came with my jack.
